DAC?
0 Members and 1 Guest are viewing this topic. Read 1362 times.
tony.ca
DAC?
« on: 25 Jun 2005, 08:19 pm »
Hi there,
 I was curious to know what does DAC mean and where is it used and what for?
Thanx,
Tony
JohnR
DAC?
« Reply #1 on: 26 Jun 2005, 12:07 am »
Hi Tony, DAC stands for "digital to analog convertor." It converts the digital signal from your CD transport (typically) into the analog signal that your preamplifier operates on.
All CD players have a DAC built into them, but may people find that the results are better if they use a separate DAC. There is a connector on the back of the CD player that outputs the digital signal.
