JVS ES1SL Problem - Please Help
0 Members and 1 Guest are viewing this topic. Read 1004 times.
gongos
« on: 25 Jun 2005, 07:10 am »
I was moving around my phono pre and its power supply. The umbilical on the back was loose, It came out and them went back in. When it did, my JVC made a little pop and then shut off. Now when I hit the power button, the blue light on the front comes on, but there is nothing in the display window, and then it shuts off automatically after 5 seconds. Any ideas what's going on?
gongos
« Reply #1 on: 25 Jun 2005, 07:14 am »
Think I figured it out. I popped the top and a fuse around the PS is blown. Hopefully, a trip to the Shack will solve my problem. I can't bear to see my $66 baby bite the dust.
gongos
JVC ES1SL Problem Update - Help Again
« Reply #2 on: 25 Jun 2005, 07:01 pm »
I replaced the fuse and the problem still exists, ie the fuse keeps blowing. Any ideas?
