4" Acoustical Cotton Factory Seconds - SOLD OUT
0 Members and 1 Guest are viewing this topic. Read 1286 times.
bpape
    • Sensible Sound Solutions
« on: 23 Jun 2005, 10:37 pm »
My supplier for acoustical cotton just informed me that they had a manufacturing SNAFU.  While making a batch of the 4" BAC, they put in too much bonding agent.  This results in the material only being approx 3" thick.  The amount of cotton is still the same so the density will be increased approx 33%.
The price has been reduced if you're interested in these 'factory seconds' by approx 25%.  Contact me if you're interested.  As of this afternoon- there were a couple hundred pieces left.  When they're gone, they're gone.
BradJudy
« Reply #1 on: 24 Jun 2005, 04:30 am »
Any idea how the NRC numbers for this batch would compare to a normal 4" panel?
bpape
« Reply #2 on: 28 Jun 2005, 11:19 am »
My guess would be that it will be down slightly for an A mount from around 70Hz down.  If you're going to use it straddling a corner, the difference will likely be minimal.
bpape
[b]SOLD OUT[/b]
« Reply #3 on: 1 Jul 2005, 01:22 pm »
All of the factory seconds are sold.  Thanks for the interest.
Bryan
