Quick Firefox question
0 Members and 1 Guest are viewing this topic. Read 1678 times.
« on: 15 Jun 2005, 01:02 pm »
How do you get the search engine to "go?"  The little search bar in the upper RH corner.
I type or paste something in to do a search and I can't get it to go.
heeeeelp.
Gordy
« Reply #1 on: 15 Jun 2005, 01:09 pm »
The enter key is all that's needed in my system.  Is there an icon for what engine you're trying to search already in the rh box?
« Reply #2 on: 15 Jun 2005, 01:21 pm »
That did it!  Enter text and hit the enter key....duh.
Google  gets the headline and there are 5 more engines listed with the ability to add more, but there is no enter key....that's what was confusing me.
Thanks, Gordy!!
Adarsh
« Reply #3 on: 24 Jun 2005, 09:36 pm »
You click the same 'go' key as for adresses.
DUH, what a numbskull you are!  :lol:
flintstone
Firefox
« Reply #4 on: 24 Jun 2005, 11:03 pm »
I didn't like the way it worked so I added the google toolbar which is found in the firefox downloads section...it  gives you the google extras also.
Dave
