Audio/Video Gear and Systems
The Lab
sts9fan
Crimp vs Solder
Crimp vs Solder
0 Members and 1 Guest are viewing this topic. Read 6084 times.
Arctos
Crimp vs Solder
6 Apr 2003, 10:10 pm »
Greetings,
I am ready to start the construction of the crossovers for my first pair of DIY 2-way speakers. Does anyone have an opinion on whether it is better to use crimp barrels or solder to connect the components together? I have read in different articles that both methods are good if performed correctly and have read that some folks even use crimping and soldering for the same joint.
Question 2: If I choose to crimp, does anyone know the proper way to crimp a crimp barrel? The reason I ask is that the barrels have a seam, and the part of my crimping tool used for non-insulated barrels has a nub on one side and a half circle on the other. Do I align the nub with the seam, opposite the seam, or somewhere in-between?
Thanks in advance for the assistance,
RDS
markC
Crimp vs Solder
6 Apr 2003, 11:51 pm »
I would personally solder joints on a crossover. I have had good, consistant results by placing the nub of the crimping tool at 90* to the seam. Have fun!
gonefishin
Crimp vs Solder
Reply #2 on:
7 Apr 2003, 02:28 am »
The only crimp I can imagine being better than a soldered connection would be when a crimp is compared to a poor solder joint.
my vote...solder!
markC
Crimp vs Solder
Reply #3 on:
7 Apr 2003, 02:40 am »
Sorry, I was wrong on the 90* thing. I meant to say that I place the nub of the tool on the seam.
Carlman
Use solder
Reply #4 on:
7 Apr 2003, 01:59 pm »
Nub goes on the seam for all crimps I've ever seen. Squeeze till it makes a little "m" shape.
I've always soldered everything inside a speaker and not used any crimps. When I've replaced wire, I've removed crimps and replaced them with solder.
Have fun!
-Carl
peranders
Crimp vs Solder
Reply #5 on:
9 Apr 2003, 01:32 pm »
I would say it is equally good soldering and crimping as long as it's correctly done. Crimping is more industrial and it's more suitable for automatic mounting.
Arctos
Crimp vs Solder
Reply #6 on:
9 Apr 2003, 06:15 pm »
Thank you all,
Looks like most feel that soldering is the way to go. The reason why I questioned this was that I read in the North Creek Wiring Guide (the North Creek folks are great to deal with and offer top quality products!!) that the best connection was a "cold weld", in which the metals from the components actually blend together. The cold weld method recommended is a non-insulated crimp. I may try some experiments and see which one gives me the best results.
Thanks again,
RDS
randytsuch
Crimp vs Solder
Reply #7 on:
9 Apr 2003, 06:24 pm »
Arctos,
I have seen posts at AA where people say crimping is better, if done correctly. Reason why is the "cold weld" you talked about. If you crimp, you should get a gas tight connection, where the wires and connector actually bond together.
You would also get a gas tight connection with solder, but then you get solder between the wire and connector, and the solder has an effect on the sound.
I think the problem with crimping is doing it right. It really takes special tools, that can apply enough force to get a gas tight connection. I think if you try to crimp with pliers, you might be better off soldering.
Randy
hoxuanduc
Crimp vs Solder
Reply #8 on:
9 Apr 2003, 07:57 pm »
Regarding building speakers...
For connection between drivers and speaker wire, I use the female fast-on terminal crimped to the wire. Easy to do, available @ HD or PartsExpress. You can remove drivers very easily.
For XO, I use brass screw and washers, easy to remove & play around, yet very tight connection.
I doubt the sound quality suffer. If you want to improve quality, play with better caps, registors & cables. I think they matter much more than the connections! I haven't seen any one comparing sound difference between solder connection vs crimp connection.
Sedona Sky Sound
Crimp vs Solder
Reply #9 on:
11 Apr 2003, 04:40 am »
Personally, I do both with all my interconnects and speaker cables. Am I able to hear a difference between crimped, soldered, or both? No. Neither could my wife who has ears like a bat.
I mainly do it for structural integrity. By putting a good crimp on things I figure that at least a good portion of the copper/silver is against the connector (the crimping theory sounds plausible so figured no need to fight it). I then use my solder station to make sure I have a good solder weld. I figure that if nothing else the solder will help strengthen the joint and also keep the copper/silver from tarnishing where it meets the connector. A side benefit of doing the crimp first is that it makes it easier to solder since everything is held nicely in place. JMHO
Julian
www.sedonaskysound.com
Arctos
Crimp vs Solder
Reply #10 on:
11 Apr 2003, 05:15 am »
Excellent info!!!
I have an idea and I would like your opinion:
I have purchased a pretty nice dedicated crimping tool (specifically for non-insulated barrels). If I twist the wires together very tightly and crimp the *** out of it
, then cover the crimp barrel in silicone caulking, I would think this would give me a good connection and also make it air tight for corrosion purposes.
What do you think?
RDS
The Lab
sts9fan
Crimp vs Solder
