Audio/Video Gear and Systems
Owner's Circles
Omega Speaker Owners
TS-3 Line Array
TS-3 Line Array
0 Members and 1 Guest are viewing this topic. Read 2849 times.
albee
TS-3 Line Array
6 Apr 2003, 08:42 pm »
Louis, hope it's not too early to ask about the line array, but could it be wired for 4 ohms as well as 8 ohms? This will have 4 drivers per side, right? It will be in the TS-3 Super cabinet? Any feel for the -3? TIA
Louis O
Industry Participant
TS-3 Line Array
8 Apr 2003, 04:36 am »
Hi Albee,
The line array is in the near future and will use TS3 drivers and Super 3 cabinet although much bigger and 4 drivers. It can be wired either 4 or 8 ohm. Should be great for the Decware. The Dipole will come first and this speaker will be available in 4 or 16 ohm. Great for Decware and OTLs. As always I do my best to keep the costs down on both models.
I will keep you posted on the progress.
The Super 3 is sounding great and I will have them at the MAF. Very easy to drive and great bass for it's size.
Louis
albee
TS-3 Line Array
Reply #2 on:
14 Jun 2003, 03:55 pm »
Louis, anything new to report on development? Thanks.
Louis O
TS-3 Line Array
Reply #3 on:
24 Jun 2003, 12:53 am »
Hi Albee,
The line array is still in the works. I have been swamped with Super 3s right now and really hard to set aside time for the Line array. Looks like it will look like a Maggie MMG only in wood and I will have it tilted back for better dispersion. Also I am playing around with the idea of putting seperate terminal posts for each driver . This would maximize connection possibilities. Dipoles are also in the future.
Thanks and best regards,
Louis
Owner's Circles
TS-3 Line Array
