0 Members and 1 Guest are viewing this topic. Read 4074 times.
the Onzow Zerodust is the most practical stylus cleaner. It is probably the most overpriced thing I ever bought, though. 70 dollars for a piece of sorbothane the size of a quarter!? . Oh well, it does the trick. Look around the house for a similar dust-attracting bit of soft rubber first. The sorbothane samples you can order from McMaster might be a good choice, but technically speaking the Zerodust's material is softer.
I also use a small sheet of soft sorbothane to clean the dust off the bristles of my record brush after sweep ...
