0 Members and 1 Guest are viewing this topic. Read 3914 times.
...I have a small room (roughly 11 feet by 11 feet with 8 foot ceiling) that I am turning into a two-channel audio room.... Originally, I was planning on putting the amp and other gear on a rack in the middle of one wall with the speakers towards the corners -- probably a foot from the wall in either direction. However, now that I'm putting it together, I'm thinking that it might be better to have the amp and rack in a corner and one speaker along each wall, angled towards the listening position.
toobluvr,How are you measuring your room? Do you use something like ETF?
Excellent advice! Thanks, everyone!Turns out I was a bit optimistic with my estimate of the room measurements -- I measured it this evening and a closet eats up some of the space, leaving me with 9.5 feet by 10.5 feet of useful space.Here's a more accurate sketch showing the door and closet. If I go diagonal, the bottom left corner will be the center. If I stick with a flat wall as the back, I can use either the top, left or bottom wall. The top wall is half window -- there is a venetian blind on it ...
