One issue to be aware of with the TEAC is the output filter
Basicly, you need to know what your tweeter impedance is above 5kHz.
The Teac really wants to see a flat 6 ohm impedance, otherwise, it will roll off early (for say 4 ohms) or having a rising response (for 8 ohms or greater)
This means a tweeter zobel (cap and resistor across +/- leads) can tailor the amp response rolloff, and significantly change the measured response. I point this out as I was looking at using using these with a 4 ohm load, but would not recommend that now, at least above 5 kHz. With a 4 ohm load, it starts rolling off at 8kHz, and is down about 3.5-4 dB at 20 kHz.
The output filter, BTW, is not the one recommended in the Tripath 2050 data sheet. I have new inductor toroids inbound for experiments to replace the stock ones.
-bob
