Speaker DIY
0 Members and 1 Guest are viewing this topic. Read 2473 times.
LFE
Speaker DIY
« on: 8 Jun 2005, 03:35 pm »
Hello all!
I just purchased a Clarinet Half Kit and can't wait to get started! I was just wondering if anyone out there knows of a good DIY Speaker kit company out there?
BradJudy
Speaker DIY
« Reply #1 on: 8 Jun 2005, 03:45 pm »
There are some good ones right here on AudioCircle like GR Research, Selah Audio, Ellis and DIY Cable.
LFE
Speaker DIY
« Reply #2 on: 8 Jun 2005, 03:49 pm »
Thanks! I'll check them out.
Rocket
Speaker DIY
« Reply #3 on: 8 Jun 2005, 11:34 pm »
Hi,
You could try Zalytron as well.  I have just purchased the phenomenal 2 speaker kit from them.  I can't tell you how it sounds at this stage though.
Regards
Rod
mcgsxr
Speaker DIY
« Reply #4 on: 9 Jun 2005, 01:21 am »
I have built a number of kits from DIY Cable, and would recommend their WR125 driver as a great place to get started with the single driver experience.
Actually, I believe the FR125 is coming out very soon, and that one should be a true high frequency driver, totally avoiding the tweeter need, for many.
Good luck with the hunt,
BradJudy
Speaker DIY
« Reply #5 on: 9 Jun 2005, 02:52 am »
Of course, I neglected to mention the mother of all DIY speaker sites: http://www.madisound.com  They sell components and kits, and have a forum with lots of active discussion.
Yoda
Speaker DIY
« Reply #6 on: 9 Jun 2005, 04:12 pm »
You should look at the Decware website--both at their offerings and the speaker builder forums.  I built the HDT's for less than $400 raw cost, and they are fantastic 96db/w/m speakers after break-in.
Matt
LFE
Speaker DIY...
« Reply #7 on: 13 Jun 2005, 04:16 pm »
I just found what looks like a great speaker project. The speakers are from www.selahaudio.com
They are the Carnelian. Has anyone built these or know anything about them?
Re: Speaker DIY...
« Reply #8 on: 13 Jun 2005, 04:27 pm »
Quote from: LFE
I think you should ask in the Selah Circle.  :wink:
