Rocket Rdes digital bass equalizer
0 Members and 1 Guest are viewing this topic. Read 1801 times.
warnerwh
« on: 6 Jun 2005, 06:48 pm »
For those of you who know that your room has a profound effect on the sound of your system here's your chance to tame the biggest problem area, the bass.  A four band digital Parametric equalizer and adjustable crossover with easy and versatile software you can use on your pc.  From the AV123 website:  "R-DES or Rocket Digital Equalization System represents a huge shift towards high quality, accurate bass in the home from almost any subwoofer. Using R-DES, you will have the ability to tune your subwoofer and correct for frequency response aberrations caused by your room. With it's easy to use PC interface and custom graphing tool, R-DES will improve the sound quality of nearly any subwoofer system available."  I will add that many of you who have no experience in working with your room that cleaning up the bass region will also make your Midrange more clear and coherent and it's more than subtle.
This is only a short time offer, shipping is only 14.95 in the lower 48.  Payment by paypal is preferred to: [email protected].  Money Orders or Cashier checks can be made payable to:
Audioware
12622 S.E. Salmon St.
Portland, Or.  97233
warnerwh
« Reply #1 on: 8 Jun 2005, 09:07 pm »
This offer will end very soon!  If you're even thinking about it now's the time especially if you don't/can't have any room treatment or bass traps.
Cheers
NealH
« Reply #2 on: 8 Jun 2005, 11:57 pm »
Does this device handle the crossover function and provide adjustments or, is it just a simple equalizer?
warnerwh
« Reply #3 on: 9 Jun 2005, 01:22 am »
The Rdes can be adjusted upto 120hz with either a second or fourth order crossover. There's also a rumble filter for below 20hz for turntables.  All equalizer functions can be adjusted for Q and frequency. The software is very easy to use, it only took me ten minutes to be up and running first time as it's software is pretty straight forward.
warnerwh
« Reply #4 on: 10 Jun 2005, 12:36 am »
Only a few more days and this price will be gone!  Back to 399.00 very soon.
warnerwh
« Reply #5 on: 14 Jun 2005, 12:24 am »
The sale price will be back in 2008, maybe. Thank You
