Which speaker?
0 Members and 1 Guest are viewing this topic. Read 1871 times.
dado5
Which speaker?
« on: 3 Jun 2005, 02:47 pm »
Primarily, I am looking for dyanamics and speed. Iwould also like the best high frequency extension possible. Bass extension is not a concern as I will be using a sub.  My amp is a 300B SET (about 10WPC).
Thanks a bunch in advance.
Rob
Which speaker?
« Reply #1 on: 3 Jun 2005, 05:31 pm »
Regarding dynamics:
IMO the FE127E "3 Series" beat the TS1 or TS2 (now called Grande 8 & 6) and integrate better with a sub.  But the driver is less efficient.  You'd have to decide if roughly 102 dB max is enough.
From all the buzz, the new hemp drivers should beat any of the above in terms of dynamics and efficiency.
-Richard-
Which speaker?
« Reply #2 on: 3 Jun 2005, 07:26 pm »
Hi Rob,
What 300B amp are you using and what preamp?
Warm regards -Richard-
dado5
Which speaker?
« Reply #3 on: 6 Jun 2005, 03:37 pm »
the 300b is a home brew. I am changing the front end of the amp from cascaded 6sn7 tubes to a transformer coupled op amp.  This is what boosts the power up to the 10W area.  Volume control is on the amp so no line pre amp.
Rob
