Audio/Video Gear and Systems
Home Theater and Video
Bob in St. Louis
Minimum room size for 7.1 setup
0 Members and 1 Guest are viewing this topic. Read 2579 times.
Valder
Newbie
3 Jun 2005, 08:44 am »
Can anyone tell me what is the min room size for a 7.1 setup? if the room is too small
should I go for 5.1 instead of 7.1?
bubba966
3 Jun 2005, 08:50 am »
What size room do you have?
I've been running 7.2 in a rather small room for years. It works fine, but the lack of software that actually uses the rear centers is what makes me usually suggest that running a good 5.1 setup is the better way to go.
woodsyi
Volunteer
Always Look on the Bright Side of Life!
Reply #2 on:
3 Jun 2005, 01:41 pm »
Supposing you can pull up to about 8' to the screen, I would guess you need another 6' to the back to put your rears. I had to put my rear ones up high and needed more space but I think they can be closer if they are lower.
Bob in St. Louis
