0 Members and 1 Guest are viewing this topic. Read 2810 times.
My thought in the diagonal setup was that the rear corner would have a significant amount of fiberglass absorption, which would help with the corner reflections and resonances. In fact, by treating all three front channel speakers and acting as a bass trap to boot, wouldn't a sufficiently wide and deep single absorber be more efficient than three separate absorption panels plus bass trap? ...
But what about all the other, non-modal frequencies? No matter the room dimensions or where you are in the room, there are still numerous peaks and nulls all over the place caused by simple boundary interference - comb filtering.
Perhaps in theory, but in practical terms he is wrong. Maybe if you could exactly match the required boost or cut, and the bandwidth, and the phase shift, you could reduce ringing for a location 1 inch cubed. But as soon as you move your head even one inch all the ringing will be right back again.
Again, only for an area one inch cubed. And I bet it took him an hour to tweak the EQ to achieve even that.
It depends on how you define "sufficiently wide." You'd probably need it to be six feet wide or even wider, floor to ceiling.
Sorry, I can't see how.
I know nothing of the papers/research you speak but I found that doing a rectangular room at a diagonal is a nightmare to deal with... twice. It's impossible to tame to the jarbled information reflecting back into the listening area... it gets harsh and fatiguing fast. At first you think, hey wow.. this sounds cool and dreamy... but then you crank it up a little and the bass is sucked out and the mids get blaring.... Treatments did nothing for me. I needed too many to be acceptable stylistically.
Stop right there. All gear has all kinds of phase shift, and the room only adds more. And it's not simple phase shift (one or two poles), but rather the sum of all the shifts from every piece of gear and acoustic sound path. There's no direct way to counter something that complex with an equalizer. And unless you counter it completely and precisely there's no chance you could reduce ringing.
How could it? The peak changes amplitude around the room, so if you cut 12 dB to fix the prime seat, you've cut too much for a location nearby.
Not if you have enough absorption! It also depends on how you define "ameliorate." You'll never get a perfectly flat response in any small room. The best you can hope for is to make it much better than it was without treatment.
I'm not enough of a math guy to understand the theory at the level needed to comment intelligently. I can say that I've been doing this stuff for many years, and I've played with EQ and speaker placement and all things related. In practice, I have never seen EQ or even speaker placement be nearly as effective as broadband low frequency absorption.
