RM30s - corner veneer
0 Members and 1 Guest are viewing this topic. Read 1953 times.
KJ
« on: 31 May 2005, 08:24 pm »
Has anyone had any issues with the corner veneer not being glued down quite right?  One of my RM30's has a one inch section of the corner wrap near the baffle that  didn't remain flush when built.  I've ignored it until now, but I'd like to see if I could heat up the adhesive and apply force to press it into place.
Anybody have any suggestions?  I was thinking of using a hair dryer to heat the adhesive, but I'm afraid I might damage the finish.
-KJ
KJ
« Reply #1 on: 3 Jun 2005, 12:40 am »
Brian - any suggestions?
-KJ
Brian Cheney
    • http://www.vmpsaudio.com
corner
« Reply #2 on: 3 Jun 2005, 01:01 am »
A cabinetshop should be able to fix the problem.  Why not send us a picture?
KJ
« Reply #3 on: 3 Jun 2005, 02:58 am »
Quote from: Brian Cheney
I didn't want to lug the speaker to a cabinet shop if at all possible.  Any idea what type of adhesive is used?  If I do take it in, I assume the 5 year warranty will cover the cabinet shop's fee?
I'll try and take a close up shot tomorrow afternoon when there is more light.
-KJ
Brian Cheney
cabinet
« Reply #4 on: 3 Jun 2005, 02:35 pm »
We will replace the cabinet under warranty if that is cheaper than a local fix.  Email the pix to [email protected].
