Cheap acoustic cloth?!
0 Members and 1 Guest are viewing this topic. Read 2336 times.
ScottMayo
« on: 31 May 2005, 02:28 am »
http://www.magnafabrics.com/category/340.htm
They claim 0.99$/yard for wide strips, in bulk. This being a whole lot less than anyone else's acoustic cloth, or even waste muslin, I'm suspicious. Has anyone bought this stuff? Is it basically loose weave scrap cheesecloth under a fancy name?
I've requested samples; I'll let people know what I find out. In the meantime, any info appreciated. They don't show color samples or give cloth weights, unfortunately...
bpape
    • Sensible Sound Solutions
« Reply #1 on: 3 Jun 2005, 05:34 pm »
Please do post when you get the material.  If it works out OK, it would be a nice option for DIY projects.  My only concern would be that being 100% poly, it might be kind of shiny to put in an HT environment.
ScottMayo
« Reply #2 on: 9 Jun 2005, 04:31 pm »
Quote from: bpape
Still waiting for my samples. They lost the first request - reading between the lines, they only sell to businesses, so the loss may have been more than happenstance. When I called back and told them I was an acoustics manufacturer (this is at best an example of artistic verisimilitude, added to an otherwise bald and unconvincing narrative - I expect to resell stereo equipment and consulting services, but I don't see myself as becoming one of Ethan's competitors), they got a *lot* friendlier.
They do 100 yard minimum orders, which happens to work for me because I need about that much.
ScottMayo
« Reply #3 on: 14 Jul 2005, 08:48 pm »
Quote from: ScottMayo
They never came though. I ended up using 11oz burlap (and I like the way it looks.)
ScottMayo
Material for traps
« Reply #4 on: 24 Sep 2005, 03:38 am »
I've spent some time looking for a material to cover two extremely large bass traps (over 10' x 10' of angled wall). I was going to go with burlap, but you can't get it in 10'+ wide strips, and I didn't want seams to show.
I finally found a decent black muslin material, available 126" wide in any number of yards. It's used in backdrops on stages, but passes enough air to be used on traps - seems to be roughly equivalent to burlap, sonically. It's a very flat deep black, not at all shiny, so it's good in video installations. It runs around 10$/yard, though.
www.iweiss.com
[email protected]
bpape
« Reply #5 on: 26 Sep 2005, 03:52 am »
But $12/yard for 10 ft wide isn't that bad.  Care to share where?
ScottMayo
« Reply #6 on: 26 Sep 2005, 12:35 pm »
Quote from: bpape
Try: www.iweiss.com
or email: [email protected]
