Cornet 2 Grounding question
0 Members and 1 Guest are viewing this topic. Read 2084 times.
fishydan
« on: 30 May 2005, 05:39 pm »
Hello-
I'm in the final stages of construction on my Cornet 2.  I have a question- Do the phono inputs connect to ground anywhere?  I see they lead to a point just under the "mono" switch.
Dan
hagtech
« Reply #1 on: 31 May 2005, 12:11 am »
The returns are indeed connected to ground at a point between the input tubes.  The jacks share this common ground in the layout.  You can either use the stock connectors or wire to panel mount insulated jacks using the same three holes on the circuit board.
jh :)
buschfsu
Re: Cornet 2 Grounding question
« Reply #2 on: 9 Jul 2011, 03:28 am »
would using non panel insulated rcas and ommiting the connection to the board be ok? its still a ground for the rcas i guess.
poty
« Reply #3 on: 9 Jul 2011, 09:28 pm »
No, it wouldn't be OK and just opposite - rather wrong decision IMHO. The only connection of the electronics (PCB) to the chassis in that case would be the Ground post connection, which would suffer from common impedance.
