Outboard Crossover Boxes (Hammond Chassis, w Binding Posts)
0 Members and 1 Guest are viewing this topic. Read 41 times.
G.Michael
Hammond chassis w thick aluminum bottom plates.  12 x 8 x 3.
Input binding posts are WBT clones.  Output binding posts are seriously nice copper ones.
From a project that didn't quite turn out.   I'll leave the old circuit in there, in case you can use any of the components or wires (and of course, because I don't want take it out of there).
As you can see, these were built for bi-wire.  All the writing on the chassis was done with Sharpies, so that it can easily be removed.
I'd like to clear $100 total on the boxes.  Another $25 for the 4-ft cables.
As for the cables, they're fairly heavy gauge.  I don't know the manufacturer.  I did compare those with arguably higher end cables in the same place (btwn crossover boxes and the speakers) and heard no significant difference.
I have a UPS account and can get good rates on the shipping.  Probably < $30 for most of the Eastern USA and < $50 for most of the Western USA.
