I'm new - came to check out Bryston
0 Members and 1 Guest are viewing this topic. Read 1090 times.
Belgian Genius
« on: 8 Dec 2025, 12:03 am »
Hi,
I'm new here, although I've been lurking at audiokarma and head-fi for years.
For years I used rebuilt vintage gear and was on quite a journey to find the best bang for the buck.
I live in Canada and I believe in North American made stuff.
Then I discovered Schiit audio.
These days my system looked like this:
Schiit Yggdrasil Singular -> Schiit Loki Max -> Schiit Freya+ -> Yamaha B2 -> Yamaha NS-1000M.
I have an electrical engineering degree, so any of the vintage gear I used was completely rebuilt and with better components, where possible.
I thought I had hit audio nirvana for the amount of money I was willing to spend....but I keep looking and as I age, I have a bit more money.
I have had a Bryston 3BSST for the past 10 years or so and it comes damned close to that B2.  So, I decided to get a new 3B cubed.  Presto!  This is the first power amp I've used that I think outperforms the B2.
Now i'm curious about Bryston speakers, so I figured it was time to join this site where Bryston has a forum.
Any opinions?  Bryston Middle T or Mini T10 vs Yamaha NS-1000M?  The NS1000 has rebuilt crossovers with the very best Mundorf capacitors and it sounds sublime.  But the bass is a bit lacking and I think the soundstage could be a bit bigger.
Mike
Re: I'm new - came to check out Bryston
« Reply #1 on: 8 Dec 2025, 12:22 am »
Welcome to AC  :thumb:
Being the B2 an power amp I wonder what are those two rotary speaker controls on the B2 at top right?
They are volume pot ?
Belgian Genius
« Reply #2 on: 8 Dec 2025, 01:13 am »
They are volume pots.  There's actually four of them, two for channel A output and two for channel B output.
« Reply #3 on: 8 Dec 2025, 01:52 am »
Incredible
opnly bafld
« Reply #4 on: 8 Dec 2025, 02:12 am »
Gain/level controls helpful for matching amplifier input sensitivity to various preamp output levels and since it has A and B speaker outputs you can adjust for different speaker sensitivity to match levels between speakers.
« Reply #5 on: 8 Dec 2025, 02:56 am »
Oh great, matching signal level is a highly desirable goal in hi-end audio as the mastering engineers dont know what they are doing.
Phil A
« Reply #6 on: 8 Dec 2025, 01:10 pm »
Welcome!
« Reply #7 on: 8 Dec 2025, 03:43 pm »
Greetings & Welcome to AC Mike   :thumb:
