Atoll IN200SE like new free shipping within CONUS
0 Members and 1 Guest are viewing this topic. Read 160 times.
boniccie
« on: 15 Nov 2025, 08:23 pm »
Selling one of my all time favorite integrated amp. The Atoll IN200SE is a true dual mono amp with a world class preamp section and HT bypass. Rated at 120W @8ohm and 200W@ 4ohm. I am using it with Magnepan 1.7i and it drives them like a champ with great dynamic and low end grip. ( check my you tube demo under moniker: Boniccie)
This is the only one for sale on the market right now and priced low @$1450 with free shipping. Pickup is always welcome at zip 84009
SPECS FROM ATOLL WEBSITE:
“True dual monaural design. Symmetrical Output stages with individual stereo channel components. Individually-powered outputs give discrete isolation in sound. Specific low consumption supplies (5VA) for analog circuits and display.
Symmetrical Output stages with discrete components
Double pair of MOS-FET transistors on each channel
Complete settings (from the front panel or with the remote control) of the balance and volume
Direct access to each inputs from the front panel or with the remote control
5 Inputs (with 1 AUX. for optional board)
By-pass input
Headphones jack
Connections:
5 audio stereo Inputs (RCA):
CD
TUNER
TAPE (IN+OUT)
AUX ( or optionnal board)
DVD
1 trigger 12V Output
1 By-pass Input (uses as power amplifier)
Double pair of Pre-out by bi-amp
Technical Specifications
Power: Wrms/channel/8Ohm: 120W
Power Wrms/channel/4Ohm: 200W
Impulse Power: 200W
Power supply (VA): 660
Total of capacitors (µF): 62.000
Inputs: 4 + 1 monitor
Input Impedance (kOhm): 220
Sensibility (mV): 100
Rising Time (µs): 2,5
Signal/Noise Ratio (dBA): 100 dB
Bandwidth: 5 Hz – 100 kHz
Weight (kg): 12
Dimensions (mm): 440x90x270mm
Some of the many reviews online:
http://www.theabsolutesound.com/articles/atoll-in200-integrated-amplifier/
https://www.hifiplus.com/articles/atoll-in200-integrated-amplifier/
https://www.soundstagehifi.com/index.php/equipment-reviews/1681-atoll-electronique-in200-signature-integrated-amplifier
https://6moons.com/audioreviews/atoll/200.html
I will ship for free within CONUS. Include remote, power cord, extra fuses. It’s in like new condition but marked as 9 just because it is used.pick up welcome as always from zip 84009. I will ship in a sturdy box with extra padding for additional safe transit. Please use paypal friends and family.
Thanks for looking!
