0 Members and 1 Guest are viewing this topic. Read 7098 times.
I'll try to keep you all posted (with before and after pictures, feedback...) I'll keep my fingers crossed
Oh yeah, I just set mine on the ground behind my TV/matching stand.
I have them controlled by X10 so that I can turn them on and off from my remote.
As for being a fire hazard, I would doubt it. I've been using mine on the ground (wood or tile) for over 4 years now. They only produce around 20 watts, which is miniscule. If you're unsatisfied with this, you could always raise them off the carpet.As an aside, I bought the original "pro" model, which was much cheaper when I bought it. I tried to use the filters, but it turns out that the amount of light produced, particularly when placed on the floor and behind a 57 inch RPTV and matching stand, is ...
