Industry Circles
GR Research
Danny Richie
LGK Build
LGK Build
0 Members and 1 Guest are viewing this topic. Read 2925 times.
Kaiju2189
LGK Build
1 Nov 2025, 08:36 pm »
Hey All,
Looking for someone to check my work on the LGK 2.0 crossover. It’s still loose and a bit messy but is it correct?
Thank you
Scott
Last Edit: 16 Nov 2025, 11:40 pm by Kaiju2189
Danny Richie
Facilitator
Re: LGK Crossover
6 Nov 2025, 06:11 pm »
I sent you a message about getting you the correct caps.
Kaiju2189
Re: LGK Build
Reply #2 on:
17 Nov 2025, 12:06 am »
I was finally able to finish my build of the LGK 2.0 speakers. My 18 year old daughter has gotten into vinyl a bit and we decided to upgrade her set up a bit nothing crazy but not bad for a bedroom setup. I cleaned up her grandfathers Yamaha YP-D71 turntable, his Project phono stage, a WIIM, streaming amp and the LGKs from GR.
I have to say thank you Danny and Scott for the help on the filter/crossover. I had a bad solder job on a connection that was causing some uneven output levels. I was able to get that fixed and WOW! The speakers sound great on their own. Of course there are power limitations and they don’t play low but they sound amazing and are absolutely invisible. I put them in my room with a little REL sub and was blown away. It made me want to build a second set to swap out with my XLS Encores from time to time.
Anyway, highly recommended! Here are some photos from the build.
tremrej65
Re: LGK Build
Reply #3 on:
17 Nov 2025, 03:40 am »
Wow. You did a fantastic job with the cabinet! Congrats.
Without music, life would be a mistake.
Re: LGK Build
Reply #4 on:
17 Nov 2025, 03:51 am »
Nice job! I built out the 2.0 and the 2.1 for my son for his gaming setup. If you are going to build out a 2nd set, I'd rec going with the 2.1 as it will go louder in a main system and it still has the single driver magic you're hearing with the 2.0.
czechm8
Re: LGK Build
Reply #5 on:
17 Nov 2025, 01:51 pm »
Very nice!
YEEEEGZ
Re: LGK Build
Reply #6 on:
18 Nov 2025, 01:00 am »
Those turned out awesome, I love the finish!
Industry Circles
GR Research
Danny Richie
LGK Build
