Mods to an old Linn 75 watt amp
0 Members and 1 Guest are viewing this topic. Read 2022 times.
guest1632
  • Guest
« on: 28 May 2005, 05:04 pm »
Hi all, Well, any one know of any decent mods to the Linn 75W amp. It's not to bad, but I want to put RCA on it instead of just Balanced connectors. That wayy I can use standard cables without having to use a Cannon connector? Plus if there are any GOOD! upgrades that would make a real difference in this little heavy beast, would definitely be interested. Otherwise, I'll probably sell it.
Ray
WEEZ
« Reply #1 on: 29 May 2005, 01:26 am »
Hey Ray,
I don't know for sure, but a phone call to John Hillig at Musical Concepts might be worth a try. (636) 272-0040
John has done mods for Adcom; Hafler; B&k; and even Levinson and AudioResearch products. He also builds his own products under the Musical Design brand.
Maybe he can give you some help or advice..
Good luck :!:
WEEZ
