X-LS Encore Standard Binding Posts Contain Ferrous Components
0 Members and 1 Guest are viewing this topic. Read 2500 times.
daschtick
Just a quick note for anyone using the standard binding posts - The nuts used on these contain ferrous metal, and are attracted to a magnet.  I swapped mine out with brass nuts from my local Ace Hardware, but I was surprised to find these in my kit purchased from GR Research.   I am sure that most will use tube connectors, but sticking with standard posts provides the greatest flexibility for my needs.
tremrej65
Yes. I noticed that on my kit as well. I had bought some tube connectors and decided to use them instead of the binding post.
What made me decide to use the tube connector is that they are compatible with male banana plug. I recommend them.
Danny Richie
We inherited a ton of those when we bought out the remaining inventory from AV123. I wish they had Brass nuts. We include them for free and only add an upcharge for the tube connectors that are much higher quality.
