newbie here - when adding a sub....
0 Members and 1 Guest are viewing this topic. Read 5337 times.
Blues Fan
« on: 18 Oct 2025, 08:11 am »
  When adding a sub.... (subs).  I am thinking Open Baffle.  Do I need a pair?  the double or tripple?  My mains are NX-3 Towers in a medium size room little treatment.  I several favorable reviews/posts.  Are the plate amps with DSP available now?
« Last Edit: 18 Oct 2025, 06:00 pm by Blues Fan »
Danny Richie
Re: newbie here - when adding a sub....
« Reply #1 on: 19 Oct 2025, 07:41 pm »
You can always start with a single Double Trouble and use it as a mono sub. If you need more output then add a second one.
The servo amps will allow you to get any response from the woofers that you want with no need for DSP augmentations.
Blues Fan
« Reply #2 on: 19 Oct 2025, 08:35 pm »
A single Double Trouble is on my list, hopefully end of year.  Thanks for the advice.
Jazzman53
  • Jazzman's DIY Electrostatic Loudspeaker Page
    • Jazzman's Electrostatic Loudspeaker Page
« Reply #3 on: 20 Oct 2025, 12:53 pm »
I love my RiPol subs, which are essentially folded-baffle dipoles with a cardioid radiation pattern.  The commercial versions are very expensive but my DIY version is affordable.
RiPol's are quality over quantity-- less efficient (85db) than boxed subs, so I always recommend a pair rather than one. Also, an outboard crossover is required, with a steep sloped low-pass <100Hz, and ideally a high-pass on the mains.
Here's a commercial version: https://6moons.com/audioreview_articles/modalakustik/
6-Moons Audio's review included this statement:
"For music-fist lovers who prioritize speed, articulation and enunciated clarity, it's the long-awaited messiah."
I share the same sentiment about mine (mine use the same woofers as the Modal Akustic sub).
A unique and amazing feature of the RiPol is that it lowers the woofer's nasty-loud fs by as much as 10Hz (-7Hz in mine), which means that it's unlikely to be excited or heard.  Only a RiPol can do this.
Compared to conventional subs, a RiPol is a bit softer on the attack but much better controlled, and it's interaction with the room gives no hint of boominess. It plays profoundly low, and gives the clearest, tightest bass I've ever heard.
I freely share my RiPol sub CAD drawing and parts list with anyone who asks.
Here's a link to my write-up, and a photo:
http://jazzman-esl-page.blogspot.com/2011/01/ripole-subs-are-underway.html
« Last Edit: 21 Oct 2025, 03:17 pm by Jazzman53 »
tremrej65
« Reply #4 on: 20 Oct 2025, 04:55 pm »
Hi Jazzman53,
Nice subwoofer. Your description of the RiPol sub matches pretty much the impression I have of the open baffle sub from GR Research. Not so efficient, but fast, precise, and fills the room evenly. I really like it. One is good enough for a small room (15x11 feet) at "normal" listening level.
You can see my build here (I spiced the design a little bit):
https://www.audiocircle.com/index.php?topic=191642.msg2008235#msg2008235
Danny Richie
« Reply #5 on: 22 Oct 2025, 10:06 pm »
The Ripol's are known as buzz boxes. The panels on each side of the woofer are unbraced and tend to see a lot of pressure, a lot of flexing, and tend to resonant like crazy.
That design also really loads the driver and can cause a response that is a big humped up area in one spot that drops off on both ends. So it is not very linear and it buzzes.
Our open baffle H frame design with servo control is in a little different league.
MarvinTheMartian
« Reply #6 on: 23 Oct 2025, 08:47 pm »
Not all RiPol's are created equal
https://www.trebleclefaudio.com/stories/true-character-of-bass
Also worth scanning Ole Siig's online pdf white papers for the whole DSP based tri amped 3 way story.
and before you ask USD $100K a pair  : (
Shawn
Danny Richie
« Reply #7 on: 27 Oct 2025, 03:26 pm »
Shawn
That is still going to aggressively load the driver and cause a narrow band hump or peak that will have to be corrected with aggressive EQ.
An actual H frame design can be used to create a more linear response that extends down a lot lower.
