Holy Grail of less than or equal to $300 Phono preamps
0 Members and 1 Guest are viewing this topic. Read 5685 times.
tubeytubeamp
Ok guys,
I have a Music Hall MMF 5 turntable with a Parasound PPH100 phono preamp. The Parasound just doesn't cut it for me. The Music is two dimensional and lacks sparkle and air. Prior to the Parasound I was using an Antique Audio USA preamp that I sold due to financial reasons. The ASUSA was much better than the parasound.
My budget is $300 used or new, tube or solid state. I have a few components to sell first before I make my purchase.
So far the only Phono-preamp I'm considering is the Channel Island Audio.
Dennis
JoshK
« Reply #1 on: 27 May 2005, 04:00 pm »
Can you solder?  I'd consider building the Cornet phono from Hagtech. Seems that lots of people rave about it and I am pretty sure it is atleast as good as the ASL phono.  Should cost about $300 to build it yourself.
tubeytubeamp
« Reply #2 on: 27 May 2005, 04:02 pm »
No soldering skills here. Is it a difficult kit?
JoshK
« Reply #3 on: 27 May 2005, 04:07 pm »
Probably not the easiest kit.  I haven't built one yet myself but have planned to.
jcoat007
« Reply #4 on: 27 May 2005, 04:26 pm »
I sound like a broken record, because I make this recomendation every time someone posts about a budget phono pre, but this is an excellent budget phono pre.  It is $399 new, but when they come up used they are usually about $250.  They used to be $299 new, but they have a much nicer case now which is probably why the price went up.
http://www.lpgear.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=LG&Product_Code=GA2PP&Category_Code=PP">Gram Amp 2 SE
I have used this unit with an MMF-5 and MMF-7 and it worked great.  I upgraded to a modified eAR 834p and upgraded my turntable as well, but I thought the Gramp Amp/MMF combo was very good.
Scott F.
« Reply #5 on: 27 May 2005, 04:36 pm »
Quote from: jcoat007
Hear hear! I second the motion!!
The Slee gear is rediculously good for the money.
Carlman
« Reply #6 on: 27 May 2005, 05:31 pm »
I too am a broken record but about the Hagerman Bugle.  You could buy it completely assembled or in kit form... www.hagtech.com.
I preferred the Bugle over the CIA in a direct comparison.  However, the Bugle was made to work well with my cartridge.
If you do not intend to change cartridges, I would use its output specs to help determine your next pre.
-C
rmihai0
« Reply #7 on: 27 May 2005, 05:43 pm »
For $100 I would chose an old NAD 1130. Is just incredible. Look on EBay and you will find one. Then, take it to a technician and ask hin to change the capacitors. You will be hugely surprised.
Good luck
nature boy
« Reply #8 on: 27 May 2005, 09:52 pm »
Bump your budget and look for a used Dynavector P-75 on Audiogon.  It's the best solid state phono preamp I have heard below $1k and I own one.
NB
jcoat007
« Reply #9 on: 28 May 2005, 01:46 pm »
Quote from: nature boy
NB
I hear the P-75 is especially good if you own a dynavector cartridge.
Carlman
Re: Holy Grail of less than or equal to $300 Phono preamps
« Reply #10 on: 28 May 2005, 02:31 pm »
Quote from: tubeytubeamp
Ok guys,
Dennis
Are you using the Goldring 1012GX cartridge that came standard on this table?  If so, I'd recommend a new cart in combination with the phono pre.  Some of the problems you describe I experienced with the Goldring.  However, I am in the minority for not liking Goldring's.  I tried the upgraded 1042? as well...  the highs were a bit unnatural to me, in my system.
I'm a big fan of moving coils.  In fact, in going through cartridges, I learned I only like MC.  If I did it over again, I'd get a low output MC and pair it with a phono pre that did low output MC well.  One day I will buy the EE Minimax phono pre.  Tubes + Coils = Long term satisfaction for Carlman. :)
merc
« Reply #11 on: 31 May 2005, 01:29 pm »
I am in much the same situation as you and I think I am gonna get an Antique Sound Labs Mini Phono II for around $250. It is a two box, tubed unit which uses a pair of 12ax7 tubes. I haven't heard it, but do have an ASL MG Head OTL headphone amp which I like alot. YMMV.
jcoat007
« Reply #12 on: 27 Jun 2005, 08:31 pm »
I'm not sure if you ever did anything with your phono stage, but here is a Gram Amp 2 SE with the old style case and $250 cheaper than a new one.
http://cls.audiogon.com/cgi-bin/cls.pl?preaphon&1125072026
rmihai0
« Reply #13 on: 28 Jun 2005, 11:39 pm »
Williams Hart / John Linsley Hood phono stage.
www.williamshart.com
rmihai0
« Reply #14 on: 28 Jun 2005, 11:39 pm »
or NAD 1130 for $100
Enjoy
rbrb
« Reply #15 on: 19 Aug 2005, 07:20 pm »
I just picked up the Cambridge Audio 640P after auditioning the 540P.  All I can say is awesome.  It's hard to believe that a preamp this inexpensive can sound so good.  I'm totally happy.  I was using a Project SE and the CA blows it away.  My table is a MMF-5
