SOLD Clear Line AC Power Plug-in Noise Filter - In Box
0 Members and 1 Guest are viewing this topic. Read 181 times.
undertow
SOLD
Price - $175.00[/color][/size]
I have one extra Clear Line available in the box.
https://www.thecableco.com/ncf-clear-line-ac.html
REVIEW -
https://www.enjoythemusic.com/magazine/equipment/0621/Furutech_NCF_Clear_Line_AC_Power_Line_Optimizer_Review.htm
Features:
1. NCF Body (multi-material hybrid structure): NCF formulated nylon resin
2. Coils: α (Alpha) Pure-Copper Rhodium-plated Conductor electrode contacts (L & N not connected – no circuit formed) and passive “Air Coils” constructed with α(Alpha)-OCC enameled wire coated a silver color resonance damping material.
3. The special T10 tamper-proof stainless steel self-tapping screws and washers
4. Housing: 4-layer hybrid NCF carbon housing composed of an outer hard clear coat over a NCF textured carbon fiber
particle composite layer with another layer of NCF and 3K carbon fiber layer beneath that. Inner surface is NCF Nylon
insulation. The best of damping and insulation materials improve frequency extension and tonal balance.
5. The internal air chamber is pressure sealed to for additional damping effects.
6. NCF End Cover (multi-material hybrid structure): Anti-static and resonance suppressing qualities with molded channels to
increase the surface area of the NCF material by 76% for improved effectiveness – ultimate resonance damping for
improved tonal balance.
 Enhance the clarity of musical performance and stereoscopic sound field.
 Eliminates noise increasing signal to noise ratio boosting information and detail in sound reproduction
 Improve the depth of the picture and improve three-dimensionality and dynamism of video playback.
 Multi-material hybrid construction: Carbon fiber housing (shell) with superior resonance damping properties.
 All conductive parts are rhodium plated and have undergone the Alpha Process.
Specifications
 Outward size: L 88.4 X W39.5 mm approx.
 Net Weight: 69 g approx.
 Suggested burn in time 24 hrs.
« Last Edit: 3 Oct 2025, 04:30 pm by undertow »
