Stack AUVA Footers
0 Members and 1 Guest are viewing this topic. Read 5093 times.
dflee
Stack AUVA Footers
« on: 28 Aug 2025, 09:09 pm »
Been reading up on their speaker footers and was wandering if anyone could shed some light on them?
Any users present or past or have you herd them and passed?
JCarney
Re: Stack AUVA Footers
« Reply #1 on: 28 Aug 2025, 09:49 pm »
Photon46
« Reply #2 on: 30 Aug 2025, 11:34 am »
https://forum.psaudio.com/t/stack-audio-auva-isolators/39888
Also, do a search on Audiogon's user forums. Lots of feedback from users in various threads.
Zuman
« Reply #3 on: 30 Aug 2025, 01:52 pm »
I have eight of the AUVA 70s under my Von Schweikert Endeavor SE speakers. Before I had the Von Schweikerts, I had eight IsoAcoustic Gaias under my previous towers, which were about the same size and weight.
This may not be helpful, because I've never done any critical listening comparisons between the AUVAs and the spikes that came with my speakers. However, I have never heard better soundstage/imaging from any system - in my home, in my audiophile friends' homes, at dealers' showrooms, or at audio shows - than I hear from my combination.
My floor is carpet over concrete, so I use the AUVAs' spiking system. It is practical and convenient, providing the speakers with a solid and stable foundation, yet also allowing me to make minor toe-in adjustments relatively easily. The AUVA feet with spikes make it easier to adjust speaker positioning than the Gaia feet, which sat on IsoAcoustics' spiked "cups."
There are obviously many reviews online from people who have made more detailed comparisons. All I can say is that the AUVA 70s have become an integral part of my VSA speakers, and I haven't felt any motivation to change them or try anything else.
Bodhi
« Reply #4 on: 30 Aug 2025, 03:31 pm »
The Stack AUVA feet are good value & work as described. For speaker iso feet, i'd rate Carbide Audio Base feet as the best. But their basic Base Micro footers cost about 70% more than the AUVA 100's, whilst the flagship Base feet cost nearly 300% more.
I'd rate the AUVA's higher than the standard Gaia feet. Though fyi, Iso Acoustics are releasing a new series of feet in Q3, 2025 which will be an evolution of the original Gaia's, which they say "deliver improvements in clarity, focus, and low-frequency definition" - https://isoacoustics.com/home-audio-isolation-products/gaia-neo-series/. Though as @Zuman noted, from a practical standpoint, the Iso Acoustics feet are best suited to hard floors or lower profile carpet. For thick pile carpet, I'd go with the Stack Audio feet.
Personally I prefer the Gaia Neo feet's height adjustment vs the AUVA's. Adjustment is via a rotating ring at the bottom of the footer which allows the feet to raised or lowered by up to 8.5mm (0.34″) without affecting its on-axis alignment, and negates the need for lock nuts. As my tiled floor is a bit uneven, that would be a handy feature. And they look nice in matt black. Though how much better they perform vs the original Gaia's remains to be seen. Once local pricing is announced, If they're good value I might order a set of 8 Gaia II Neo feet with the next speakers I plan to buy.
toocool4
« Reply #5 on: 30 Aug 2025, 03:32 pm »
Have a look at this review of a few footers, including the Stack Audio.
https://www.youtube.com/watch?v=32DrKCqLWkk
Bodhi
« Reply #6 on: 31 Aug 2025, 12:13 pm »
I visited the Stereonet Hifi Show in Melbourne this weekend, and had a chance to check out the new Iso Acoustics Gaia Neo feet. They're designed to sway laterally which I thought was interesting. Fit and finish was very good, and the height adjustment seemed to work well. That said, I haven't seen the AUVA's in the metal, but I known Shane Stephenson (aka: "An Aussie Audiophile") thinks highly of them.
