APPJ Mini2013 6J1 6P1 Vacuum Tube Amplifier New Old Stock – $79/Each
0 Members and 1 Guest are viewing this topic. Read 188 times.
baileyler
APPJ Mini2013 6J1 6P1 Vacuum Tube Amplifier New Old Stock – Several Available
This listing is for a new-in-box APPJ Mini2013 6J1 6P1 vacuum tube amplifier.
Price is $79 plus shipping (where required, see below).  I have several units available.
Published specifications are as follows:
Voltage amplification tube: 2*6J1
Power amplifier tube: 2*6P1
Output power: 3W+3W@4/8 ohm
Frequency response: 30-40KHZ (-1dB)
Input sensitivity: 500MV
Signal to noise ratio: -80dB/3W
Residual noise: <1mVac
Input AC voltage: 100-250V AC
Power consumption: 36W
Input impedance: 10K ohm
Output impedance: 8/4 ohms (Japan’s Z11-EI48*24 output transformer)
Dimensions: 124 mm (width) x 132 mm (D) x 166 mm
Packing size: 186 mm (width) x186 mm (D) x 155 mm
Weight: up to 1.7kg
Package weight: up to 2.0kg
Input: RCA jack
Output: banana socket
AC: standard IEC socket, fuse protection (2A fuse)
Each unit comes with the original box, amplifier and tube set.  Color is black.
There is no power cord included, but it uses a standard IEC power cord which is readily available.
At this moment I do not have any extra 6J1 or 6P1 tubes, but they are not expensive and readily available from Ebay and many other places.
Prior to shipping, I will test the tubes to make sure they are reasonably within spec.  Unless otherwise instructed, I will also do a basic test on the unit to make sure the amp is operational and passes sound.
A unit is available for a local demo.
Additional information and photos are available on request.
GENERAL TERMS AND CONDITIONS
Please note that these units are being sold ‘AS IS, WHERE IS”, and all sales are FINAL.
I am more than happy to demo a unit prior to sale.
Preferred payment is cash or Paypal.  Money order/cashiers check/personal check can be accepted, but all must clear my bank first.
A CONDITION OF ANY ELECTRONIC PAYMENT IS THAT YOU EXPRESSLY WAIVE THE RIGHT TO FILE A CLAIM OR CHARGE BACK with the payment vendor (but do retain the right to sue me in my local court should you so desire).
Local pickup is available (Kennett Square 19348).
If required, shipping will be via USPS Priority Mail unless otherwise requested.  Shipping weight is 5 lbs.  Please inquire for further details and a shipping quote.
Please check my feedback on Ebay (ID=baileyler) and buy with confidence.
