newbie- need advise
0 Members and 1 Guest are viewing this topic. Read 4794 times.
satishjasti
newbie- need advise
« on: 25 Aug 2025, 05:46 am »
want to build good system to listen to music, want to build using eversolo DMP-A10 + eversolo AMP-f10 + speakers (TBD), any suggestions? once these are decided, will check out speakers. Have sony AVR ES7000 +ML speakers, not good for listening to music.
Re: newbie- need advise
« Reply #1 on: 25 Aug 2025, 02:23 pm »
First off, what is your room like?  Hopefully not small or squarish.  Always match speakers to the room.  At 200 wpc/8 ohms the Eversolo AMP-f10 can handle nearly any speaker.  Audition using a variety of music you're familiar with and take notes.
satishjasti
« Reply #2 on: 25 Aug 2025, 03:37 pm »
thanks for the advice, room size 14 x 14 ft.
Phil A
« Reply #3 on: 25 Aug 2025, 04:56 pm »
Welcome!
toocool4
« Reply #4 on: 25 Aug 2025, 05:07 pm »
Welcome to AudioCircle satishjasti
The only way to know the correct speakers to match what you have is to go and listen to as many speakers as you can. If you can get a home trial, that would be the best and if not you may need to take your kit to the dealer’s if they don’t have your setup.
By trying in your own room with your kit, is the only way you will truly know what gels with the rest of your kit and you.
Good luck.
I.Greyhound Fan
« Reply #5 on: 25 Aug 2025, 07:11 pm »
What is your budget and what is the power rating of your amp?
« Reply #6 on: 27 Aug 2025, 02:24 pm »
Greetings & Welcome to AC   :thumb:
