SOLD: Pangea Quattro Premier XL Power Distribution Strip plus 20A to 15A Adapter
0 Members and 1 Guest are viewing this topic. Read 203 times.
pstrisik
  • Holding pattern in Audio Nirvana in the PNW!
====SOLD====
Top of the line Pangea power distribution strip. Provides quality expansion from outlet of existing power center or directly from the wall. Includes a heavy duty power cord with 20A connector at the Pangea end. If you prefer to use your own power cable, I'm including the Pangea 20A-15A Adapter that was purchased separately. Fully functional with minor signs of use.
Original cost was $299 plus ~$20 for adapter. Yours for $165 with $15 shipping anywhere in the U.S. No fee paypal f&f or buyer covers any transaction costs. 100% positive feedback over many years, USAM, Audiogon, and ebay.
Quattro Series Overview
Four-outlet Power Distribution Strip with Sealed, All Metal Cabinet
Premium Audio-Grade 20A/15A [NEMA 5-20] AC Outlets
Pure Power Path with Zero Current-Limiting Internal Components
Includes Heavy-duty 5-ft. Detachable AC Power Cord
Choose Premier, Premier SE, or Premier XL
Dimensions: 9.5″ x 7.7″ x 2.7″
Pangea Audio Premier Quattro XL AC Power Distribution Strip
Four premium 20A/15A outlets
Gold-plated beryllium copper contacts
Cardas Grade One Copper internal wiring
I'm including the Pangea Audio 20A-15A IEC Gold Plated Connector that I purchased separately so you can use your own power cord if you prefer...
Use Your 15-Amp Power Cable with 20-Amp Gear
If you’ve got a premium 15-amp AC power cord that you’d love to use with an AV component that only has a 20-amp IEC, you need this handy adapter from Pangea Audio.
The female IEC end of the Pangea Audio 20A-15A IEC Adapter accepts any standard male IEC-terminated power cable. The male IEC end plugs into a component that uses 20-amp IEC power cords.
The molded, one-piece polymer body is strong enough to hold heavy power cords snugly in place, while the ridged, easy-to-grip design makes it easy to plug-in and unplug. The heavy-gauge copper contacts help to optimize power delivery. The gold plating on the contacts resists corrosion.
« Last Edit: 29 Aug 2025, 06:37 pm by pstrisik »
