0 Members and 2 Guests are viewing this topic. Read 481358 times.
Jihad! Have fun, folks, adios!
Recently the thread has taken a turn toward Believers vs Objectivistswith the usual oversensitivity in the believers camp, and getting into thatkind of debate can ruin the discussion.
I feel compelled to point out though that some of the same people, who said in the past that the B200 produced plenty of bass by itself, are now searching for bass fill solutions. I don't think anyone here is from the camp of "a rulerflat response is the be all to end all", and we're all just after great sound, tous, in our rooms. I also don't think anyone can argue that there is anythingwrong with a flatish response or that an uptilted response can sound any more "real". Flat response at your listening position means hearing the recordingplayed accurately, however, getting there can introduce other problems.When you are used to rolled off bass, be aware that when you first implementbass fill it can sound very bass heavy. I experienced this first hand and it took a couple of days for my ears to adjust to a much flatter and extended response.
Visaton's response graph shows just what the driver sounds like, and there is some content missing at the very top, however, it does go high enough for most.
...it's possible to use wings that concede nothing to a flat baffle in terms of sonics, while retaining some key sonic and visual advantages. I believe this because I took a small flat baffle and altered it into a winged version going through many stages until the imaging equalled it's small box counterpart (something I've yet to obtain with a flat baffle), but kept the large open sound of the OB flat baffle. Because I have multiple driver pairs, I was able to make direct comparisons throughout the process, since using our (edit-MY) audio memory is totally unreliable.
The truth is the B200 can put out a tremendous amount of low end energy, so much so that I sold my Augies. I don’t want to offend anyone here, but in relation to the B200 in my system, I found the Augies to be slow and muddy while not offering any useful extension. A single pair of B200’s in my room mounted on the baffles I made with wings produces superb low end energy in both quality and quantity, almost to the point of being boomy!
