Introduction Im here to fight latency
0 Members and 2 Guests are viewing this topic. Read 1373 times.
Max Appeal
« on: 11 Jul 2025, 11:04 pm »
Hey all, Anyone know of other bit perfect multi combinations of rainbows 14bit bitperfect analog like HIBY thats similar?
apparently since before ASIO sold us WASAPI software dll as a hardware feature to fix different recording and playback of AV with random awful lousy lags and malwares false bios and emulation with firewalled off no access to any hardware for 'virtual stuff' in 97 the ASIO didnt fix it and itanium fakery kernel proxying requiring kernel bypass or kernel proxy bypassing for any sort of sound or video related stuff to ever occur.. you've likely not ever used a 0 latency original first ever HDMI cable or type C cable also 0 latency at anywhere near 0 latency when ps2 was close enough you could just be like okay lets call it that and ps3 was real super computer 0 latency why does new modern computers or android devices past 12 have sky high latency and sound awful? I hadnt seen many audiophile players but whats better than a hiby R4 evangelion edition android 12 or just the hiby F5 dac amp USB C in any samsung phone with some config text files to specify lower latency for the API and configure the bios for low latency? it advertises femtoseconds but you can specify omniseconds and biseconds or zepto seconds or quettaquectoseconds for the whole OS and or API with any OS or device using a text file.
when dvd's and blurays came out i learned how to master and create them for clues on how to PLAY THEM.
I bought into the dolby receivers and atmos receivers often a pioneer or onkyo that had the better opamps which were burson brown but really just always texas instruments ones so now its CHEAPER! I then played around with cheap chifi xduoo dac amps or  random tiny brands and IEMs of various KZ or other brands with different bluetooth 5.0 swappable wired cables or different crystalline OCC continuous cast oxygen free copper/silver/gold cables and settled on pairing them with hifiman overears so i dont develop ear infections.
Im just a regular old guy from sydney australia early 40s wants to hear sounds that sounds like sound.
I realised HIFIMAN had some great over ears affordably which pair fantastically with android phones and external dac amps which i ended up replacing with HIBY F5 USB dac amp
turns out most people dont know AC3 isnt a file format its an audio convolver setting and convolution maths is just 3 different equations to 2D to 3D to 4D squares to tesseracts but for audio using dolby raidiation aperture horizon lens flare maths of reality apertures. a dolby ray is a type of lens flaring that looks like neon genesis AT fields and signifies a barrier to realities and existing. atmos takes regular bluray dolby audio of 9-13 channels and discretely generates realtime 19-23 channels for like in movie theater celing speakers but its object oriented like uhh video game surround sound EAX positional footsteps that youre supposed to director emphasize when mastering.
but with our OS having so much lag all the WASAPI exclusive mode doesnt help.. that said DAUM POT PLAYER a remake of linux KMplayer with tweaks and plugins DOES help D3D11 rendering exclusively but not so much.
So now i wanna find more brands like HIBY and if theres anything better than an RS6 or RS8 player cheap the audiophile stores test and trouble shoot with those to diagnose with the best audio possible clearest cleanest.. i take some hifiman R9's on the train closed back with the F5 purple hiby dac amp. I use a custom text file config file for lower audio latency but its only a subtle slight difference you maybe wont hear it you gotta listen carefully or have a good hardware setup but the lower latency helps.. its just like ASIO vs regular. copy the config file text files to documents folder 36 in all for android linux and on windows u maybe need to hardware DEP all software turn on all exploit protection and ensure core isolation and hardware stack protect is ON or they disable it.. Also script blocking means u maybe gotta open it in a new browser tab also theres a thing with hacker vpn bullshit that limits your windows desktop session i made regkeys to try and fix just run the shorter filename reg key each reboot and open the xml file once or a dozen times in browser to see it looking a fraction of what it previously did with the ONE config file.
https://www.4shared.com/s/fJxo9iu5Ejq
https://www.mediafire.com/file/cnunfl11d1jpa0f/QUETTAQUECTOENHANCEDULTRAEXTREMEMULTIVULKANAMDRYZENRADEONCOMPLEXITYDIRECTXKERNELVERSIONBUILDRELEASEUNITYMAXIMUMULTRAEXTREMEENHANCEDGRAPHICSQUALITYSETTINGSNEXTQUETTAQUECTOFFFFFFFF99999999.5FFFFFFFF.7z/file
