New member question
0 Members and 1 Guest are viewing this topic. Read 4585 times.
gate28
New member question
« on: 9 Jul 2025, 05:12 am »
Hullo. probably a basic question for those here, but question is.
I have a pair of Tannoy M4 speakers. I accidentally drove a pretty weird audio signal through my amp last night, not loud enough to distort. However, now the speakers sound dull, muted, muffled. The speakers all still work individually ( I removed them) Is it possible to have damaged the crossovers only? There are also no fuses or anythig visibly broken on the croosover. Thanks in advance. Ralph NZ.
« Last Edit: 10 Jul 2025, 12:57 am by gate28 »
Re: New member question
« Reply #1 on: 9 Jul 2025, 12:44 pm »
Do you can remove the woofer and check it and the crossover?
gate28
« Reply #2 on: 10 Jul 2025, 12:59 am »
Hi Thanks for the reply. i removed all speakers (3) and they all work when attached directly to the speaker wires from the amp. If I was to check the crossover, how would I do that with a multimeter, and what normally blows? Thanks.
« Reply #3 on: 12 Jul 2025, 04:03 am »
Unfortunately to test resistors with multimeters needs remove the resistor from the circuit.
Set the multimeter to the resistance setting then connect the probes to each end of the resistor. The multimeter will display the resistance value.
Compare the measured value with the resistor color code chart.
If the measured value is within the acceptable tolerance the resistor is likely good.
If the reading is near zero the resistor may be shorted.
If the reading is infinite the resistor is open, damaged.
Inductors are hard to be brokem.
Capacitors will die in some years.
« Last Edit: 12 Jul 2025, 05:45 am by FullRangeMan »
richidoo
« Reply #4 on: 12 Jul 2025, 04:52 pm »
Just because a tweeter still makes sound doesn't mean it is healthy, and it is impossible to judge the performance of any portion of the intended bandwidth of the speaker without the whole bandwidth playing.
To test drivers' health you need to measure the electrical impedance of the speaker and/or the drivers using a tool like DATS.
Also measure the acoustic frequency response of the whole speaker to quantify what the "dull" sound really means, using a tool like OmniMic.
Post this data for advice on what might be wrong, but it will probably be rather obvious.
It is unlikely that any signal within the power rating would damage Tannoy crossover.
Often seemingly disconnected circumstances are actually connected. And seeminingly unconnected circumstances are not related. Something else that you didnt notice may have happened that you blame on the test signal. Or the test signal damages sometimg else besides speakers, or speakers arent really damaged.
You have to use scientific method to test and prove to know what's really going on.
Swap in different components, cables, check connections, etc. dont assume anything.
I once blamed every components in my system over a yearlong period for a random ticking sound coming out of the left speaker, or so I thought. It turned out to be nail pops in the wall behind the speaker when the sun hit that part of the house in the afternon and again at night when house cooled. It took a year to figure it out because I was stuck on "it's coming from stereo system"
