New Preamp Decision
0 Members and 1 Guest are viewing this topic. Read 6140 times.
Delta77
New Preamp Decision
« on: 26 Jun 2025, 04:42 pm »
I've been contemplating a new preamp.
Currently using a Decware CSP-3 as my preamp/headphone amp.
Current system:
Denon-  DP-59L (Turntable)
Decware - (phono pre)
Innuos - Zen (streamer/server)
Holo audio - Spring 3 (DAC and remote Volume control)
Decware CSP-3 - (Preamp) to switch between the Turntable and the DAC, No remote volume control
Deware - Mystery (amp)
Aric Audio - 300B (amp)
Tekton - Double Impact SE (speakers)
ZMF - Auteur (headphones)
I really want a Aric Audio preamp (Super 6SN7), but it's about $4,500. Don't think I can spend that much on a preamp (when I already have one).
In the mean time I have been talking with Apollo Audio, and thinking about trying one of their preamps "Maia" for around $3,000 with upgraded caps.
Has anyone here used or have any experience with Apollo Audio Systems.??
Or any other suggestions to throw into the mix.??
Thanks Delta....
« Last Edit: 10 Jul 2025, 11:46 pm by Delta77 »
Nick B
Re: New Preamp Decision
« Reply #1 on: 26 Jun 2025, 11:11 pm »
I have a Hattor Big preamp that I got used for less than $2000. My unit has the AMRG gold resistors and the New Class D opamp. It's a very well built unit and the remote works flawlessly and it's very functional. In my system, it sounds best in the +9dB setting. Very clean, clear, detailed. Not sterile or analytical at allI can highly recommend this unit.
Charles Xavier
« Reply #2 on: 27 Jun 2025, 01:39 pm »
If you wait a bit you can find a Aric pre used for about 3500
Early B.
« Reply #3 on: 27 Jun 2025, 01:49 pm »
Agreed. There are no gut pics of the Apollo gear and no description of the parts quality. With Aric, you know exactly what you're buying, and the sound quality is exceptional (I'm a previous Aric owner -- I sold the amp to my friend).
Rocket
« Reply #4 on: 9 Jul 2025, 01:22 pm »
Hi,
You may want to consider an AVA FET VALVE CFR PREAMPLIFIER cost is less than what you were considering plus 30 day return if you don't like it.
Cheers Rod
/mp
opnly bafld
« Reply #6 on: 9 Jul 2025, 10:48 pm »
This Apollo?
https://www.apolloaudiosystems.com/
Paul Birkeland of Bottlehead fame is the lead designer and a prolific designer/builder with excellent quality.
Here is a very long thread with many of his commission builds.
https://hifihaven.org/index.php?threads/more-amp-construction.4673/
Highly recommended.  :thumb:
Delta77
« Reply #7 on: 11 Jul 2025, 12:27 am »
“This Apollo?”
“https://www.apolloaudiosystems.com/“
Yes opnly bafld, that would be the guys I’ve been talking with.
First of all Thank you guys for all the suggestions and advice..!
I have been speaking with Brandon. I saw some crossovers he has been upgrading in customers homes. Made me think ,this guy must be a very passionate audiophile to run around the country and help others get the most out of their systems. Then I found out that the head designer was Paul Birkeland of Bottlehead. At that point I let my guard down a little, and felt it wouldn’t hurt to give a preamp a try. If it improves my system I will keep it, if it doesn’t I will have to let him know. I know sometimes using new equipment might not be “better” just different. Will see how well it will fit in my current system. I’m hoping for a slightly fuller sound (if that is the correct description). Of course it will need to have very low, to no noise, hiss, hum, ringing.
I’m not a complete beginner to tube gear, but still have a lot to learn. In my 4-5 years, I haven’t heard or seen anything about the No. 27 tube. Guess I have some research to do.
Delta
snaimpally
« Reply #8 on: 16 Jul 2025, 02:19 am »
For a 6SN7 preamp, Tubes4HiFi has the SP14: https://www.tubes4hifi.com/SP14.htm
This is basically the same preamp that Don Sachs used to sell - you can see Don's comments (and comments of others) on that page. If you are handy, you can build it and save some money or buy it pre-built for around $2k.
