BDA 3.14 Qobuz tracks interrupted
0 Members and 1 Guest are viewing this topic. Read 2646 times.
Mr.Vertigo
« on: 24 May 2025, 10:30 am »
Hi guys, I'm new here and unfortunately I can't use the search function yet. If my problem has already been addressed in another post, I apologize.
I am using a bda 3.14 to stream Qobuz with Manic Moose. I have a few problems with the software and hope that the new Qobuz Connect app will work with the bda 3.14 soon.
But my main problem with Manic Moose is that individual tracks on Qobuz are repeatedly interrupted after a few seconds. For example, when I play the album “Famous Blue Raincoat” by Jennifer Warnes, the first track “First we take Manhattan” breaks off after 13 seconds and goes on to the next track. The rest of the album plays perfectly. Everything works fine with the Qobuz app on my ipad on the same network. I have already tried all the solutions suggested by Google AI 😂, unfortunately nothing has helped.
Any idea what the problem could be?
gbaby
Re: BDA 3.14 Qobuz tracks interrupted
« Reply #1 on: 30 May 2025, 11:09 pm »
This has happened to me using the BDP3. Are sitting anything on top of the BDA 3.14?
stereoal
« Reply #2 on: 31 May 2025, 04:27 pm »
I've not had this problem with Manic Moose, but have another problem: Songs are missing on some long albums and box sets (it appears Manic Moose has limits on album lengths) and in other albums none of the songs are there. This has happened with both Qobuz and Tidal. Unfortunately, Manic Moose is long overdue for a replacement. I keep hoping . . .
Mr.Vertigo
« Reply #3 on: 1 Jun 2025, 10:02 am »
Thank you for your reply gbaby!
It is a very pure second system without additional devices - BDA 3.14 with 2.5B cubed (speakers are Bryston Mini A, SVS Micro 3000). BDA 3.14 is connected with LAN cable to a Wifi extender. And as I mentioned, the Qobuz app works perfectly with my iPad via the same network. It is also independent of whether the tracks are HiRes or not.
I'm actually very tolerant and can overlook many, sometimes funny problems with Manic Moose. For example, I have 13 albums by Charlie Haden on my hard disk and the cover of the thirteenth album is not displayed. If I manually change the album name so that another album is the thirteenth, the cover of that album is not displayed... and so on.
But what's really annoying is when you can't listen to tracks because they just stop after a few seconds.
Did you find a solution for the same issue with your BDP3?
« Last Edit: 1 Jun 2025, 11:04 am by Mr.Vertigo »
