What does the "magic date" for the 3960 mean?
0 Members and 1 Guest are viewing this topic. Read 1182 times.
albee
« on: 23 May 2005, 01:50 am »
A fellow posted on AA and said he found one that was made before 06/04 and bought it.  Was there a significant internal change that effected the sound?  Me puzzled.
geneylim
« Reply #1 on: 23 May 2005, 10:46 pm »
The change effected the picture quality...they switched from a Toshiba chip to a Zoran chip. Not sure if they changed the audio dacs...
Vinnie R.
    • http://www.vinnierossi.com
« Reply #2 on: 23 May 2005, 11:02 pm »
Quote from: geneylim
The did not change the Burr-Brown DAC...I've modded both the early and later date 3950s and 3960s, and they all use the same dac.
albee
« Reply #3 on: 24 May 2005, 12:22 am »
Thanks, amigos.
