SOLD P10 - MM Phono Stage / Amp Latest Version U.K. NOS W/Telefunken Tubes
0 Members and 1 Guest are viewing this topic. Read 252 times.
undertow
PayPal F/F only payment 48 State Shipping Included
SOLD = $795
Rare on the used market is the latest version of the PureSound P10 Phono stage from the U.K.
This unit is pure tube with linear power supply.
MM only so only requires 2 tubes.
Tube #1 is a 12AX7 / ECC83 current tube in unit is an NOS Telefunken
Tube #2 is a 6922 / 6DJ8 current tube in unit is an NOS Telefunken
- MM Gain = 40 db perfect for most MM or use of Step Up transformer with MC
- Unit has Earth Ground lift switch on back which will eliminate if you have any hum and ground post
- Single ended input and output Gold RCA jacks
- 15 amp IEC and will come with a basic IEC cable
- Excellent overall working and cosmetic condition
- Runs very cool, and dead quiet, can be run in cabinet or stacked vents are on the sides
- Unit ships in original factory boxes
Tube rolling very easy with just 2 tubes, and you do not need matched pairs
There will be 3 tubes shipped with the unit a $500 value each tube currently costs about $175 NOS these all have been tested for microphonics balanced triodes and are NOS status -
* 1 - Telefunken NOS 6922 / 6DJ8 in the unit
* 1 - Telefunken NOS 12AX7 / ECC83 in the unit
* 1 - EXTRA Telefunken NOS 6DJ8 in box as seen in photos
Dimensions- 13โ€ Deep, 8.5โ€ Wide, 4โ€ Tall
http://www.puresound.info/id13.html
https://theaudiophileman.com/p10-phono-amplifier-pure-sound-review/
« Last Edit: 5 May 2025, 08:00 pm by undertow »
