Ok, I'm still not getting something here. Check out these tiles:http://www.truesoundcontrol.com/products/VERST24.htmlThey don't list much data about them, other than representative NRC. Why would I buy your system over these tiles, especially since these tiles will cover 48 lineal feet? (And I ask this question because I have a beam that is parallel to my speakers and needs to be treated; I'm just trying to figure out what to buy to treat it.)As for whether to treat first reflection points or the corners, I do believe that corners would be better to treat.
Certainly questionable. I keep thinking of the proof that a bumblebee can't fly. With 3.8 hours, is sounds like an error in the equation.
It looks like we will have to agree to disagree on most of these points. I am not saying that you do not have a grasp of the current understanding of room acoustics, I am saying that the current understanding of room acoustics is wrong.
Exposed absorption ALWAYS overattenuates high frequencies leaving you with a bottom heavy frequency response. By overattenuating high frequencies, you reduce much of the areas of the frequency bands where distortion is most apparent, which is percieved as the reduction of echo, and the increase of detail.
The point is, it's not a matter of "using" the reflected wave. Reflection is part of the system, whether it fits in with our ideals of how sound should be reproduced or not, and it is even a bigger part than the direct wave itself. And since most of the sound we hear is reflected sound, exposed absorption rolls off the high frequencies for the sounds we hear. What we hear is the sound we are concerned about, isn't it?
The bridge film is worth seeing, it is a standard physics example of resonance. A large suspension bridge starts swaying then twisting a full 90 degrees over the course of a minute or so and eventually breaking and toppling down, all because the wind blowing across the bridge excited its resonant frequency amplifying the effect of the wind. Amplification is the key here.
My entire reponse to this of course can be seen above. It is a nice ideal, and it sounds good on paper, but anyone who has listened in an anechoic chamber will tell you that it does not in fact sound natural, and does not sound like "you are there." This leaves us with only one conclusion, that we do not yet understand what is necessary to recreate the original event, and until we start looking at things differently, we won't make any progress.
Where can I find this Carl Saunders recording? I looked at his website, and it's not in his discography...
In a "a fully reinforced environment where sound can travel in only one direction without expanding," the wave quickly becomes a plane wave, and ideally does not dissapate at all (think waveguide). And by a quirk, (I love physics and it's quirks, or was that quarks?), that is the same condition for an enclosed box, as long as all reflections are ideal.
When sound travels through a medium, its intensity diminishes with distance. In idealized materials, sound pressure (signal amplitude) is only reduced by the spreading of the wave.
I *believe* your -3dB/meter refers to the intensity of a cylindrical sound wave rather than the propagation in a cylinder. This is how a wave behaves when it is captured between two plates (think sonar in a *shallow* ocean). There is definitely application for this in rooms, but I don't think in how you used it.
My core problem with the model suggested was that was/is deriving an "ideal rooms" maximum RT60. Nathan's chain of logic showed that RT60 for "any given space cannot exceed 6/100ths of a second." He didn't buy that amount himself. I was offereing another way to get there that gave answers that exceed his derived max. I think both he and I would agree that the real world values can only be less than the ideal.I don't believe RT60 only exceeds 0.06 sec. for resonant frequencies. Yes, my values are somewhat larger, but remember they are *ideal*. The inverse square law *does* apply to reduce the intensity of the sound from the moment it is generated at the speaker until it fills the room. Interactions at the room boundries (walls, carpet, furniture, people, etc) absorb a lot of energy. And then there's what "leaks" out of whatever openings there are, or even possible Helmhotz resonator effects. All of these will quickly bring my "not to exceed" values down to what you should experience in a real-world situation.
An Anechoic Environment to a Stereo Listening room is like a "Totally Darkened" theater to a motion picture. [ ...
The "most of the sound we hear is reflected" argument, is not valid, and went out with Bose 901's. It is only valid at the original venue, not in reproduction.
Quote from: John CaslerAn Anechoic Environment to a Stereo Listening room is like a "Totally Darkened" theater to a motion picture. [ ...Is this a good thing? Just as most filmmakers are going to light their sets and expose their film in a way that is going to look the best in "normal" movie-viewing circumstances (which is not a "totally darkened" theater), I would guess that most recording engineers don't record things to sound best in an anechoic listening environment...Oh..thanks for the CD info!
Saying that most of the sound we hear is not reflected based on the sonic qualities of the Bose 901 speakers is a little naive, don't you think? The math is simple and the physics are clear. .
Your assertations that you have listened to a hi-fi system in a truly anechoic chamber have not been clear. Your listening room is far from an anechoic chamber, and most anechoic chambers are not truly completely without reflection, they decay at a significant enough rate that they are considered anechoic. It is engineering after all. And besides, even if there were a perfect anechoic chamber where you would only hear the "direct sound wave", your very presence in it would cause reflections, as would the speakers, etc .
I understand that you enjoy listening to music in a LEDE environment, and good for you. I find it hard to believe however that you can stand on your soapbox and flat out proclaim that it is the only way to accurately listen to music based on your knowledge of some acoustic engineering principles and "40 years of experience." 40 years of breathing wouldn't make me an expert on the molecular makeup of air. .
I am sorry if I seem harsh, but I must admit that I am a little curious as to why you inject your theories into a thread where people are asking me how my products work. This isn't the first time, and I'm not the only acoustics manufacturer you have done this to. You certainly have a right to your opinions, and to share them. But to push them over and over, when they are not solicited is frankly a little strange. I do not refute every post that you put up which are many and that I obviously disagree with. I answer direct questions as frankly and honestly as I can. You know, I do design acoustic products for a living, and some people really seem to like them. I must not be entirely wrong, ya know? .
“The "only" frequencies and sound that is accurate and important to accurate reproduction, is the "direct" sound. (unless as I said earlier you are trying to "mimic" a specific recording engineers environment -- which is futile)”
This source discussed the same mathematical models for sound wave propagation for a slightly different example, but I hope that the analogous situation is clear:http://www.squ1.com/index.php?http://www.squ1.com/sound/propagation.htmlFrom there:A point source in free space exhibits the inverse square law, and a 6dB reduction in intensity per doubling in distance.A line source exhibits the inverse law, and a 3 dB reduction in intensity per doubling of distance.And a plane source exhibits no reduction in intensity.
The other part of my questioning that value is that if it were that high, I wonder how we would hear anything over any kind of range. One resource I could find puts talking at 55-65 dB at 3 feet - say one meter. If the attenuation coefficient is -3dB/meter, then I wouldn't be able to hear normal talking levels from beyond 20 meters - 65 feet. And that doesn't include any reduction due to spreading, inverse square, inverse, or otherwise.
I do definitely agree that in trying to reduce RT60 for low frequencies that we may make the room dead for HF. But I would say that we're trying not to overattenuate the HF rather than to amplify it.
I haven't been following this whole thread, but from what I understand, the reflective outer surface provides a benefit in that high frequencies reflect off the surface, thereby not reducing absorption of these frequencies. But then you said that the reflective outer surface acts to reflect sound from the walls back through the material. Ah, I see. What you're saying is that the reflection/diffusion off the front surface acts to limit the amount of sound getting to the corner, which therefore limits the "amplification" by the corner. Moreover, any sound (in certain frequencies, of course) that does get behind the material will get reflected back through the material (and perhaps this could go on several times, from the corner surfaces to the reflective surface and vice versa), thereby further reducing the "amplification" by the corner. Is my theory correct?
There is very little difference between heat and sound transfer. Haven't you noticed that good insulators of heat are also good insulators of sound and vice versa? ...
the assumption that lower frequencies take a significantly longer time to decay, but that is only applicable for room modes which are amplified...
Are you saying that "mixing" reflected room sonics "adds" accuracy?
The Bose 901 was based on the "clear physics" you (I think) are referring to. It is how much reflected sound we might hear in our everyday natural environment, in the real world.
I think my very first post to this thread was that I "was not" preaching.
Quote from: 8thnerveThere is very little difference between heat and sound transfer. Haven't you noticed that good insulators of heat are also good insulators of sound and vice versa? ...NO. How about styrofoam, just to begin with
I'have yet to see a measurement which can show that the decay at the room mode is disproportionately higher and not caused by physical resonance of the wall surface.
