0 Members and 1 Guest are viewing this topic. Read 26364 times.
Interestingly enough, a friend told me that room treatment would deaden the room. While this is true for some products, this is not the case with 8th Nerve approach, because it is reflective in the front and absorptive in the back. In fact natural ambience and room liveliness is improv ...
Room treatment is also controversial for me (used alone without ambience recreation) because it will make the ambient sound of the listening room even more unnatural, compared to any live event.
CSERO wrote: QuoteRoom treatment is also controversial for me (used alone without ambience recreation) because it will make the ambient sound of the listening room even more unnatural, compared to any live event.Interestingly enough, a friend told me that room treatment would deaden the room. While this is true for some products, this is not the case with 8th Nerve approach, because it is reflective in the front and absorptive in the back. In fact natural ambience and room liveliness is improv ...
While I may not agree with their "reflective properties" (hey guys why not offer both reflective and non-reflective??) I certainly agree that corners and points of first reflection are the begining...
The products have to be reflective to reflect the sound coming from the corners back into the corners. Otherwise the distorted energy would still come into the room, but the higher frequencies would be attenuated... not what we want.
The products have to be reflective to reflect the sound coming from the corners back into the corners. Otherwise the distorted energy would still come into the room, but the higher frequencies would be attenuated... not what we want...
Hi Nathan,Sorry if I misunderstood the "reflective" surfaces of your product.I thought that the "front" (facing the listener) was reflective. Is that not true?From your clarification, I get that the "backside" (facing the corner) is reflective???
Why does exposed absorption reduce high frequencies? Is your reflective material band-specific?
The side of the product facing into the room is reflective, so you were right in your understand. But it is reflective in both directions. The reflective front is really for the sound coming from the corner, which travels through the fiberglass, hits the reflective surface, then reflects back towards the corner through the fiberglass again and repeats the cycle. This allows us to burn off the sound coming from the corner. .
The only benefit from the front also being reflective is that we are not presenting any exposed absorption. Exposed absorption ALWAYS overattenuates high frequencies leaving you with a bottom heavy frequency response. By overattenuating high frequencies, you reduce much of the areas of the frequency bands where distortion is most apparent, which is percieved as the reduction of echo, and the increase of detail. It is essentially the same as Dolby Noise Reduction. Unfortunately you also lose all the delicate upper harmonics that encode the characteristics of instrumental timbre, space, and environment.
The reason I say that I don't treat the first reflection points is that the sound is arriving about 4/1000ths of a second later and at a level of about -4db (normal sized listening room). The sound from the front tri-corners is arriving at about 10/1000ths of a second later at a level of -0.12db. This is an order of magnitude more significant, and is only from one of the many corner surfaces of your room, all more important and harmful than the first reflection by a large margin.
Hold on! Then how is it possible to have RT-60 times that are longer than 6/100ths of a second? Well, the only way to increase the total amount of energy in a system is to amplify it. Room modes are a good example. The geometry of a room causes resonant frequencies which amplify the sound at a given frequency. Most of us have seen the film of the bridge that starts twisting and swaying as the wind excites its resonant frequency. This explains room modes, but what about everything else?
Quote from: ctviggenWhy does exposed absorption reduce high frequencies? Is your reflective material band-specific?Because all absorptive material to date absorbs more high frequencies than low frequencies. All materials have varying degrees of performance at different frequencies, we look for those that are as linear as possible across the audible band.
The goal to accurate reproduction is to subtract/absorb/block all "room" generated interaction and sonic artifacts.
The goal is to make the room boundaries "acoustically transparent"...
... so that the sonics heard by the listener will reproduce the "acoustic boundaries" (sonically) of the original venue (assuming there were some) contained in the recording.
Having two sets of "sonic space" acoustics destroys the original.
I might tend to disagree with that.
I cannot agree that the energy from reflected sound should be "used" as you're suggesting.The "only" frequencies and sound that is accurate and important to accurate reproduction, is the "direct" sound. (unless as I said earlier you are trying to "mimic" a specific recording engineers environment -- which is futile)Exposed absorption only attenuates "reflected" HF sound.
You lost me on the bridge.Room Nodes/Modes are caused by sonic energies "opposing" each other "DIPS" or "summing" with each other "PEAKS/SPIKES".
Alternatively sound is also reflected (bass is the best example since low bass is spherical in its radiation) off the front wall.
But the goal, is not to preserve the "sum" of all the HF (or any frequency) in the room, direct and reflected.The goal to accurate reproduction is to subtract/absorb/block all "room" generated interaction and sonic artifacts.The goal is to make the room boundaries "acoustically transparent", so that the sonics heard by the listener will reproduce the "acoustic boundaries" (sonically) of the original venue (assuming there were some) contained in the recording.Having two sets of "sonic space" acoustics destroys the original.
The laws of physics dictate that in a cylinder, a fully reinforced environment where sound can travel in only one direction without expanding, sound decays at a rate of 3db per meter. In free space sound decays at a rate of 6db per meter. A room is a semi reinforced environment, and it's decay rate should fall between these two numbers. Even at the maximum sustain rate of -3db per meter, sound travels at 340 meters per second through air at sea level. This means that the RT-60 (time it takes for sound to decay by 60db) of any given space cannot exceed 6/100ths of a second. Since we have never seen an RT-60 time that low in any environment, and a good RT-60 time is considered to be around 50/100ths of a second, with many rooms measured at over 1 and a half seconds, something else must be happening.
20 Hz 0.000013 dB/m100 Hz 0.00029 dB/m1,000 Hz 0.0047 dB/m10,000 Hz 0.16 dB/m20,000 Hz 0.52 dB/m
The need for "accurate" would assume that what is on the record is faitful and complete representation of the sonic event.
John Casler wrote: The goal is to make the room boundaries "acoustically transparent"... You can not reach that. You ocan only hope, that after heavy treatment the sound of your room is no more deterimental than the chairs, audience etc around you in a real concert hall, and blend in the same benign way. But the more you treat, if you don't do anything else, the farther you move acoustically from any venue where music played
John Casler wrote: ... so that the sonics heard by the listener will reproduce the "acoustic boundaries" (sonically) of the original venue (assuming there were some) contained in the recording. It is simply not possible, especially not with a stereo speaker pair. A "live" record played back in a dead room sounds like a "live record played back in a dead room", not like the original acoustic environment. The "acoustic boundaries (sonically) of the original venue" are around you, so the reflected sound comes from every direction. The ear is quite sensitive to the directionality of this. That's why a front speaker pair will never reproduce a realistic ambience. Also IMHO that is the reason that the lack of bass impact of hi-fi, compared to any live event
John Casler wrote: Having two sets of "sonic space" acoustics destroys the original. Agree. That's the single biggest reason why the audiophile demo music is (closemiked) small jazz combo or LGWG music
