0 Members and 3 Guests are viewing this topic. Read 44877 times.
If I get one of the finished Rythmik subwoofers will it be the same sound or does the GR Research open baffle design make all the difference?
I have the Popori WR-2's in a Bacch curated system with room correction.The bass is good but the -3dB point i would say is 100Hz or higher.This could be wrong as it's by ear without any measurement.I see that a sub is used by some with Poporis -(Housteau).I'm looking for a compatible sub to mesh with the Popori Electrostatics.i've looked at GR Research's Open Baffle and the Rythmik subwoofers.I've also seen the Magnepan bass system.i've heard none of them.Any suggestions?
OK, are there any open baffle Rythmic type subs with a finished cabinet?
An awful lot depends upon at what frequency you will be rolling your sub bass in at. With the WR2 that frequency should easily be around 50Hz and below. At such lower frequencies speed should not be any issue of concern. However, if you are crossing over much higher then speed does become more important the higher in frequency you go.
They said their in-room -3db is around 100hz so a blazing fast sub is critical in this application.Also, even with lower crossover points, I've found out (through trial and error) it's still best to use OB subs to match with OB main speakers. Planars and electrostatics in particular benefit from them.
The only concern I have about using the open baffle subs in such a case is that they may lean more towards that quickness and speed where it isn't required, since the Popori are handling that. In doing so they may lack presenting that needed strong foundation.
What I have found is when the main speaker radiates bass in a figure 8 pattern, like here, then you really really want to have the sub match that pattern. Box subs stick out like a sore thumb because they radiate like a pulsing sphere. Makes perfect integration almost impossible.
Housteau, I think you use bass cone drivers with your Poporis with an upper cutoff of 38-42 Hz for the bass cones. Which one(s) are you using? Are they Rythmiks or some other brand? When I use a tone frequency sweep to test the output of my WR-2s I can hear the tone clearly down to 100Hz but then the sound output level (SPL) from the Poporis starts to drop significantly. I can still hear the tone down to about 50Hz when it disappears completely. Is this room treatment interfering or just my old ears?StandardModel
