SOLD: Lumin U2 Streaming Transport in Black
0 Members and 1 Guest are viewing this topic. Read 491 times.
pstrisik
  • Holding pattern in Audio Nirvana in the PNW!
« on: 19 Apr 2025, 06:09 pm »
=====SOLD=====
Essentially new.  Purchased April 2025 from store with no return. Unfortunately, does not meet my needs for inputs if I am to use my Auralic VEGA as a dedicated DAC. Within 12 months, I can get 100% credit towards anything from the store, but nothing I want to go for at the moment.
I have confirmed with Lumin that the 2 year warranty is transferable and I will provide the original receipt from an authorized dealer.  Now it is a true "open box" purchase!
As new (essentially an open box), $4395 $4200 net to me (after shipping and any transaction costs). Shipping from Bellingham, WA 98225. Available for local pickup. Save on taxes and beat the tariffs. People are scrambling to buy existing stock as new shipments will get hit with the tariffs from China.  Reasonable offers considered.  But keep in mind that I have a year to trade at full value.
Auralic has suspended shipments to the US due to tariff uncertainty.  Look up the Lumin U2 at Upscale Audio.  They raised the price from $5000 to $6000 due to this situation.
I will include a TP-LINK MC200CM Media Converter with no extra charge. This will be half the fiber connection. To use the fiber ethernet, you would also need a SC to LC fiber cable and one optical transceiver that inserts into the fiber cage on the Lumin. Ethernet cable plugs into the media converter which outputs via the fiber cable to the Lumin.
Purchase worry free as I have 100% positive feedback on USAM, Audiogon, and eBay.
Transport-only unit featuring the finest LUMIN components:
First LUMIN Transport to use new all-in-one chassis
Latest processor provides greater resampling flexibility
New integrated toroidal linear power supply
Fibre Network provides complete isolation from network digital noise
Increased capacity for future updates
3 USB ports including a NEW dedicated low-noise USB output
Dual-Network interface with built-in Network Switch
DSD512 and PCM768 playback
4 exceptionally low-phase-noise crystal clock oscillators
New surface finish taken from the high-end P1
Leedh Processing lossless volume control
U2 Specification
DSD Support:
Up to DSD512 22.5MHz, 1-bit
PCM Support:
Up to 768kHz, 16–32-bit, Stereo
Upsampling rates & bit depths:
DSD256 upsampling option for all files
PCM 384kHz upsampling option for all files
Digital Output Stage:
USB:
Native DSD512 support
PCM 44.1–768kHz, 16–32-bit, Stereo
Optical, Coaxial RCA, Coaxial BNC & AES/EBU:
PCM 44.1kHz–192kHz, 16–24-bit
DSD (DoP, DSD over PCM) 2.8MHz, 1-bit
Optical Network:
Industry-standard SFP
1000Base-T Gigabit Ethernet
Adapter may be needed for your particular switch/cables
Use simultaneously with RJ45 (e.g. connect one to router and one to LUMIN L1 or NAS)
Power Supply:
Internal toroidal linear
Low-noise linear regulator
Physical:
Finish:
Black anodised aluminium
Raw anodised aluminium
Dimensions
350mm (W), 350mm (D), 60.5mm (H), 6kg
« Last Edit: 4 May 2025, 06:33 pm by pstrisik »
pstrisik
Re: FS: Lumin U2 Streaming Transport in Black
« Reply #1 on: 26 Apr 2025, 11:23 am »
Reduced to $4200
