Some help with line stabilizers...
0 Members and 1 Guest are viewing this topic. Read 1023 times.
thepogue
« on: 21 May 2005, 11:44 pm »
HI all...Just picked up two Tripplite Isobar Line Stabilizer/Surge Protectors for my system. I had a certified POS before so I'm very much pleased with the lower noise ceiling from the Tripps...but I've got two questions. I've got my amps plugged into the Tripps and I've head that's not a good idea...I've not had any issues to date but I've not cranked my system since using the Tripps..so what the buzz?...what is it not a good practice to plug your amps in to a surge protector...
the second thought is my units have eight outlets each...I run mono blocks so my system is pretty much split down the middle...one Tripp had the amp, pre, TT, DAC and a single speaker and the other has amp, CD, DVD (for burnt CD's as my parasound doesn't like them) and a single speaker. the eight plugs have four outlets that are marked "Isolated" and the other four are marked noise filters "first level, second lever...etc...etc.."...I plugged my amp, speakers, pre and TT in the isolated outlets first...then just filled in the rest...anyone got any thoughts on this?...thanks for the help!!
Pogue
clubmyke
« Reply #1 on: 22 May 2005, 02:53 pm »
i wouldnt use the conditoner on the amps...
 they draw a fair amount of current.. but that is just me (i have tried a couple differnt power conditioners on my  classe cam 350 mono's and it really closed them in for my taste)
have you upgraded your power cords ????  that has really changed the voice of my system big time....
arthurs
Conditioners
« Reply #2 on: 22 May 2005, 05:24 pm »
The only conditioner I have found to date that didn't seem to limit the sound of my amps is the Audio Magic Stealth XXX, which I bought and still own....
