Old Stratos Extreme Upgrade & Repair
0 Members and 1 Guest are viewing this topic. Read 6553 times.
Locofinn
« on: 20 Mar 2025, 02:07 pm »
I acquired an older Stratos Stereo Extreme that looks almost new but is failing to power up. I plan on getting with Klaus to bring it back to life. This unit is maybe 18 years old according to the original owner. Is there any other upgrades anyone has done that you recommend I take care of while it is under repair?
JCarney
Re: Old Stratos Extreme Upgrade & Repair
« Reply #1 on: 20 Mar 2025, 02:45 pm »
When you call Klaus, he will ask you questions about your system so he can tailor the amp to your system. Make sure you call him after 10pm central time, dude is a night owl. He will walk you through what he thinks should be done to the amp to get the best sound for you.
Good Luck,
JCarney
