SOLD: Simaudio Moon 340i D3PX in excellent condition 9/10
0 Members and 1 Guest are viewing this topic. Read 413 times.
Beatlebum
SOLD! For sale here is a Simaudio Moon D3PX two-tone silver and black integrated amplifier in 9/10 condition. It s optioned up with a high performance DAC and excellent MC/MM phono stage. Original owner purchased from an authorized dealer in 2022. Pet free smoke free home. This high current amp was never run hard as I usually listen at levels around 70db.
Condition is excellent with a small scratch/smudge on the front that I did my best to capture in a photo. The remote was used very little and still has the plastic on it.
Original box and packing materials.
6 (six) line level inputs and front mounted 1/8" mini-jack for personal media players
1 (one) pair of balanced input (XLR)
Headphone output on 1/4" jack located on front panel
A massive, oversized power supply using a custom toroidal transformer design
340i X Integrated Amplifier The MOON 340i X is the ultimate example of a world-class yet affordable integrated amplifier. Combining high power, sonic finesse and superb flexibility, the MOON 340i X will seduce you with its musical authority, as well as its rich, engaging and lifelike sound quality. An optional built-in MC/MM phono stage and a high-performance DAC (32-bit/384kHz + DSD) round out this compact nerve-center for your music system. Finally, balanced inputs round out plethora of connectivity options the 340i X offers. 6 (six) line-level inputs including a front-mounted 1/8” minijack for personal media players. 1 (one) pair of balanced input (XLR). Headphone output on 1/4” jack located on the front panel. A massive oversized power supply using a custom toroidal transformer design. “Class A” output to 5 watts for greater efficiency. One audio input which functions as a “pass-through”, bypassing the gain stage to accommodate components like a home-theater processor, whose own volume control is used instead. Precision matched proprietary MOON Bipolar output transistors for improved bass response and accurate sonic reproduction. Available finishes are dependant on location Available Finishes Black 2-Tone simaudio.com Input Sensitivity 370mV - 3.0V RMS Gain 37dB Input impedance 11kΩ Signal to Noise ratio 110dB @ full power Output power at 8Ω 100W per channel THD (20Hz - 20kHz @ 1W) < 0.015% Output power at 4Ω 200W per channel THD (20Hz - 20kHz @ 100W) < 0.05% Crosstalk -88dB Intermodulation Distortion (IMD) < 0.03% Optional Digital Inputs S/PDIF, USB, Optical Maximum PCM Resolution 32-bit/384kHz DSD sample rates DSD64, DSD128 & DSD256 Frequency response (full range) 2Hz - 90kHz +0/-3dB Shipping weight 28lb/13kg Dimensions (width x height x depth) 16.9 x 3.5 x 14.8 in 42.9 x 8.9 x 37.6 cm
Shipping to CONUS only. All shipping costs to be by the buyer. Paypal F&F only (no tax implications wanted). Ships from zip code 33913.
« Last Edit: 16 Mar 2025, 09:04 am by Beatlebum »
