0 Members and 1 Guest are viewing this topic. Read 6190 times.
Hi,I’m maybe planning to also do an crossover upgrade by Tony Gee. I’m actually very happy with the tonality of my Spendor A7 speakers and don’t want that to change that much. I’m wondering if it could sound more open, playing with more ease and flow. With some more refinement, texture and layering, so without changing the tonality, or changing the sonic character or sound signature.What can I expect? Is it possible with just upgrading the existing parts?I’m a bit hesitant because I don’t know how it would turn out. At the moment I can listen to my set for hours without being annoyed by something I want to change. So it’s nice and balanced, even with a dual sub integration.
For about $500 in parts for the crossover upgrade, you can SIGNIFICANTLY improve the sound without altering the tonality. If you aren't comfortable with a soldering iron, get a buddy to rebuild the crossovers for you. It would be a fun Saturday afternoon project for him.
I would think about the situation differently. If I was investing $500 to improve the sound of my system where is that money best spent given my current setup?
So you guys think I can really get what I wish for by upgrading this crossover with the same value of higher quality parts?Grtz
Hi,I’m maybe planning to also do an crossover upgrade by Tony Gee. I’m actually very happy with the tonality of my Spendor A7 speakers and don’t want that to change that much. I’m wondering if it could sound more open, playing with more ease and flow. With some more refinement, texture and layering, so without changing the tonality, or changing the sonic character or sound signature.What can I expect? Is it possible with just upgrading the existing parts?I’m a bit hesitant because I don’t know how it would turn out. At the moment I can listen to my set for hours without being annoyed by something I want to change. So it’s nice and balanced, even with a dual sub integration. ...
Hey! Using more expensive parts doesn't always guaranteed better sound than what you have you now... it could just be different flavor that fade over time. Of course there's no way to know until you installed those "upgraded" parts in and give it a listen... preferably after break in. I would recommend you be careful removing the original parts so it can be reinstall if you don't like the sound of the new upgraded parts. By the way... those caps I see in the pic I 6.8uf caps... the more expensive caps at that value would be pretty big so make sure you have room for them. Good luck and keep us posted.
How can you create a "more open sound, with more ease, flow, refinement, texture and layering" without changing the "tonality, sonic character or sound signature"?I did a quick search among a couple popular hi-end crossover caps;6.8uf Mundorf Supreme Classic Silver/Gold in oil, 51mm dia x 50mm long, $254.6.8uf Duelund CAST Cu/Sn, 165mm dia x 29mm wide, $580.
........ Using more expensive parts doesn't always guaranteed better sound than what you have you now... it could just be different flavor that fade over time. ...............
Hi Wolff, let me tell you that upgrading the XO can bring the improvements you are looking for. I have upgraded many many XOs even on some 'high-end' speakers with easily heard benefits.Do not worry about the alarmists saying it might be worse, the basic tone of the speaker remains but with more clarity, detail and openness. Voicing a speaker? It doesn't work like that. The designer produces a XO that under measurement shows a good response and then uses components that are priced to fit the budget and that is itUsing better components will, under measurement, show the same response therefore not changing the character of the speaker.That will get you a big lift in performance. It would be easier to advise if I saw a schematic of the XOGood luck
