SOLD: Rotel RA1572 MkII $1400 shipped
0 Members and 1 Guest are viewing this topic. Read 695 times.
Sarchi
« on: 26 Feb 2025, 08:28 pm »
Received in a trade. This powerhouse integrated amp retails for $2100 and is less than two years old. In perfect condition. Asking $1400 Paypal shipped CONUS.
RA-1572MKII
The RA-1572MKII Integrated Amplifier brings your music to life with exceptional fidelity delivering 120 Watts of Class AB output into 8 ohms with deep, controlled bass energy. The audiophile grade DAC, analog, digital, aptXTM and AAC Bluetooth, PC-USB supporting MQA and Moving Magnet Phono stage ensure exceptional detail and immersive soundstage. Roon tested.
Dimensions (W × H × D) 431 × 144 × 358mm
(17" × 5.7" × 14.1")
Front Panel Height: 3U / 132.6mm (5.25")
Power Requirements 120V, 60Hz
Power Consumption 400W
Standby Power Consumption <0.5W
Net Weight 13.63kg (30.05lbs.)
BTU Rating (4Ω, 1/8th power) 810 BTU/h
Maximum Power Output 200W/Ch (4Ω)
Continuous Power Output 120W/Ch (8Ω)
Total Harmonic Distortion (THD): <0.018%
Frequency Response
Line Level Inputs: 10Hz - 100kHz, ±0.5dB
Digital Inputs: 10Hz - 90kHz, ±2dB
Phono Input: 20Hz - 20kHz, ±0.5dB
S/N Ratio (IHF "A" Weighted)
Line Level Inputs: 100dB
Digital Inputs: 100dB
Phono Input: 80dB
Intermodulation Distortion (60Hz:7kHz, 4:1): <0.03%
Damping Factor 300
Input Sensitivity
Line Level Inputs (RCA): 270mV
Line Level Inputs (XLR): 440mV
Digital Inputs: 0 dBFs
Phono Input (MM): 2.1mV
Input Impedance
Line Level Inputs (RCA): 100kΩ
Line Level Inputs (XLR): 100kΩ
Digital Inputs: 75Ω
Phono Input (MM): 47kΩ
Input Overload
Line Level Inputs (RCA): 4V
Line Level Inputs (XLR): 5.5V
Phono Input: 32mV
Preout Level 1.5V
Output Impedance 470Ω
Coax/Optical Digital Input Signals
LPCM (Up to 24-bit/192kHz)
PC-USB
USB Audio Class 1 (up to 24-bit/192kHz)
USB Audio Class 2 (up to 32-bit/384kHz)*
*Driver installation required
MQA and MQA Studio (up to 24-bit/384kHz )
Roon Tested
« Last Edit: 18 Apr 2025, 02:00 pm by Sarchi »
Sarchi
Re: FS: Rotel RA1572 MkII $1400 shipped
« Reply #1 on: 17 Mar 2025, 11:58 am »
Bump
Sarchi
« Reply #2 on: 25 Mar 2025, 02:10 am »
Bump
Sarchi
« Reply #3 on: 8 Apr 2025, 01:29 am »
SOLD
« Last Edit: 18 Apr 2025, 01:59 pm by Sarchi »
