FS: $350 LH Labs Geek LPS Linear Power Supply 12V DC output Brand New
0 Members and 1 Guest are viewing this topic. Read 339 times.
mtruong34
Asking $350
BRAND NEW IN BOX NEVER USED! First photo is stock photo. Others are actual item.
Geek LPS is a linear power supply that has been designed to convert “dirty” AC power from wall outlets to “clean” DC power that is optimal for all high end electronic equipment especially digital-to-analog converters (DACs).
It has one 12 volt DC outputs.
This “clean” power has very low signal noise which improves the sonic quality of music, making it sound much more natural.
An additional benefit of the LPS is the ability to reduce the signal noise of the USB connection from the computer to the DAC, adding to the sonic improvements. Just connect your computer to the LPS using a USB cable, then connect LPS to any USB DAC using a second USB Cable. When you do this, LPS disconnects the 5V power coming over the USB cable from the computer and replaces it with clean (under 6uV noise) 5V power coming from its super-regulated power circuits.
Special note: With USB 2.0, cable length is very important. You cannot go longer that five meters in total length and expect consistent results. Because Geek LPS does not include a repeater or amplifier (due to noise concerns), the sum of the lengths of both the input and output USB cables cannot exceed five meters.
Terms: Shipping $29 to CONUS only. No international shipping. Returns accepted only if DOA. For Paypal please add 3% unless using Friends & Family or by bank account.
mtruong34
