Tube Amps and Preamps
0 Members and 1 Guest are viewing this topic. Read 1742 times.
ADSNAD
« on: 17 Feb 2025, 12:49 am »
I have never owned a tube amp or preamp and have several questions about them:
What level or type of speaker is necessary to hear enough of a difference to justify the cost increase over solid state?
Is it worth having a tube amp if you don't have a tube preamp and vice versa?
What are some good entry level brands for tube gear to experiment with?
thanks!!
Mike
nlitworld
Re: Tube Amps and Preamps
« Reply #1 on: 17 Feb 2025, 05:53 am »
You can have a lot of fun playing with some tubes. Most commonly for people to dip their toes is a tube preamp and solid-state amp. As for speaker demands with tube amps, try not to combine low power single ended amps with low sensitivity or hard to drive speakers. That goes the same with any amp/speaker combos though. A great cost effective step into tubes, look at Tubes4HiFi. Kits available if you're handy with a soldering iron or assembled for a couple extra bucks. Hell of a good way to get your feet wet.
