For Sale: Luxman SQ -N150 integrated amplifier
0 Members and 1 Guest are viewing this topic. Read 550 times.
rwanda
« on: 9 Feb 2025, 12:20 am »
 Mint Luxman SQ-N150 here with all original items and original box. I am the original owner and has been an amazing amplifier with a variety of speakers. The built in MM and MC phono stage is quite good and would be wonderful for those using vinyl. It has had light use as I rotated with with several other amps I own.
The unit will ship in original box and double boxed.
Punches well above its power rating:
Rated output: 10W+10W(6Ω)
Input sensitivity/impedance:
PHONO (MM): 3.0mV/47kΩ
PHONO (MC): 0.33mV/100Ω
LINE: 180mV/47kΩ
Frequency response:
PHONO: 20Hz to 20kHz (±0.5dB)
LINE: 20Hz to 80kHz (within -3.0dB)
Total harmonic distortion: 1% or less (1kHz, 10W/6Ω)
S/N ratio (IHF-A):
PHONO (MM): 84dB or more
PHONO (MC): 64dB or more
LINE: 95dB or more
Circuit: Driver :P-K split phase inversion circuit
Output: Pentode power tubes
Vacuum tubes: ECC83×3, EL84×4
Power supply: 230V~(50Hz) / 115V~(60Hz)
Power consumption: 98W
Dimensions (WHD): 11.7" x 7.4" x 9.9"
Weight: 27.3 lbs.
Accessories:
Remote control (RA-25)
Power cable
asking $2100 shipped in lower 48
prefer Zelle or Venmo but can take PP friends&family
« Last Edit: 9 Feb 2025, 07:08 am by rwanda »
